VLAN BETWEEN 951Ui-2HnD x RBcAPGi-5acD2nD ON WIFI
I would like to configure a VLAN between RB951Ui and CAP ac being that it was centralized in RB951Ui. The idea would be for me to create a VLAN on the RB951 and be able to control all devices that connected to the CAP by Wifi. It is possible?
Yes it is possible…
You can set a default VLAN-Tag for all connected device,
on the Wireless-Interfaces on your Mikrotik-Device.
(Exemple: vlan-id=123 vlan-mode=use-tag)
If you need Help with your Setup
Please Post Config of the 951Ui
(/export hide-sensitive file=anynameyouwish)
