I whent with a different approach,
On my router I have port#1 as WAN, and on interface port#2 I have created 3 vlans - 192, 172 and 10. I Have configured a DHCP server for each vlan.
On my switch I have the following setup:
[root@MikroTik_Switch] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-m... 1500 E4:8D:8C:A8:56:72 enabled none switch1
1 RS ether2 1500 E4:8D:8C:A8:56:73 enabled ether1-master switch1
2 RS ether3 1500 E4:8D:8C:A8:56:74 enabled ether1-master switch1
3 S ether4 1500 E4:8D:8C:A8:56:75 enabled ether1-master switch1
4 S ether5 1500 E4:8D:8C:A8:56:76 enabled ether1-master switch1
5 S ether6 1500 E4:8D:8C:A8:56:77 enabled ether1-master switch1
6 S ether7 1500 E4:8D:8C:A8:56:78 enabled ether1-master switch1
7 S ether8 1500 E4:8D:8C:A8:56:79 enabled ether1-master switch1
8 S ether9 1500 E4:8D:8C:A8:56:7A enabled ether1-master switch1
9 S ether10 1500 E4:8D:8C:A8:56:7B enabled ether1-master switch1
10 S ether11 1500 E4:8D:8C:A8:56:7C enabled ether1-master switch1
11 RS ether12 1500 E4:8D:8C:A8:56:7D enabled ether1-master switch1
12 S ether13 1500 E4:8D:8C:A8:56:7E enabled ether1-master switch1
13 S ether14 1500 E4:8D:8C:A8:56:7F enabled ether1-master switch1
14 S ether15 1500 E4:8D:8C:A8:56:80 enabled ether1-master switch1
15 RS ether16 1500 E4:8D:8C:A8:56:81 enabled ether1-master switch1
16 S ether17 1500 E4:8D:8C:A8:56:82 enabled ether1-master switch1
17 S ether18 1500 E4:8D:8C:A8:56:83 enabled ether1-master switch1
18 S ether19 1500 E4:8D:8C:A8:56:84 enabled ether1-master switch1
19 S ether20 1500 E4:8D:8C:A8:56:85 enabled ether1-master switch1
20 S ether21 1500 E4:8D:8C:A8:56:86 enabled ether1-master switch1
21 S ether22 1500 E4:8D:8C:A8:56:87 enabled ether1-master switch1
22 S ether23 1500 E4:8D:8C:A8:56:88 enabled ether1-master switch1
23 RS ether24 1500 E4:8D:8C:A8:56:89 enabled ether1-master switch1
24 S sfp1 1500 E4:8D:8C:A8:56:8A enabled ether1-master switch1
[root@MikroTik_Switch] /interface ethernet switch ingress-vlan-translation> print
0 ports=ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,
ether13,ether14,ether15,ether16,ether17,ether18,ether19,ether20
service-vlan-format=any customer-vlan-format=any new-customer-vid=192
pcp-propagation=no sa-learning=yes
1 ports=ether23,ether24 service-vlan-format=any customer-vlan-format=any
new-customer-vid=10 pcp-propagation=no sa-learning=yes
2 D ports="" service-vlan-format=any customer-vlan-format=any new-customer-vid=4095
pcp-propagation=no sa-learning=no
[root@MikroTik_Switch] /interface ethernet switch vlan> print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 D 4095 switch1-cpu no no no no none
1 X 10 ether1-master no yes no no none
ether23
ether24
2 X 172 ether1-master no yes no no none
ether2
ether3
3 X 192 ether1-master no yes no no none
ether2
ether3
ether4
ether5
ether6
ether7
ether8
ether9
ether10
ether11
ether12
ether13
ether14
ether15
ether16
ether17
ether18
ether19
ether20
root@MikroTik_Switch] /interface ethernet switch egress-vlan-tag> print
# VLAN-ID TAGGED-PORTS
0 D 4095
1 10 ether1-master
2 192 ether1-master
3 172 ether1-master
ether2
ether3
I now have port 23 & 24 as edge ports in vlan 10 - as wantet - and everything is fine here.
I have port 4-20 as edge ports in vlan 192 - as wanted - and everything is OK.
On port 2 & 3 I think I have hybrid, with vlan 192 as edge, and 172 as tagged? Theese ports are connected to my AP`s (Ubiquiti AP AC-LITE), where I have one SSID without specifying vlan - this works great, and I am recieving IP as wantet from vlan 192. But I have a second SSID where I have specifyed vlan 172, but I am not getting any IP when connecting to this SSID.
Any suggestions? You might wonder why I have disabled vlans in: /interface ethernet switch vlan
This is simply because when I activate these, I am not longer able to manage the switch from other ports than 21 & 22 witch is not listed in any other vlan configuration…
