Hi all,
The diagram below depicts my current setup:
The RB5009 has a IP on VLAN1 (192.168.88.1) and on VLAN 10 (172.16.10.1), providing DHCP services, which works fine.
The CRS has a management IP on VLAN1 (192.168.88.2)
On my CRS I have some ports dedicated to VLAN1, some VLAN10.
When I enable VLAN filtering on my CRS, everything seems to work fine for a while. Eventually, however, I'll lose access to the CRS's management IP, nor can I connect to it via MAC in Winbox
RB5009 Config:
# 2025-09-17 11:01:16 by RouterOS 7.19.6
# model = RB5009UG+S+
add admin-mac=<omitted> auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface vlan
add interface=ether8 name=vlan10-dg vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=vlan-10-pool ranges=172.16.10.10-172.16.10.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=vlan-10-pool interface=vlan10-dg name=dhcp-vlan-10
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge tagged=bridge,ether8 vlan-ids=10
add interface=vlan10-dg list=LAN
192.168.88.0
add address=172.16.10.1/24 interface=vlan10-dg network=172.16.10.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.228 client-id=1:0:11:32:e5:79:5b mac-address=\
00:11:32:E5:79:5B server=defconf
add address=172.16.10.0/24 dns-server=192.168.1.1 gateway=172.16.10.1 \
netmask=24
192.168.88.1
set allow-remote-requests=yes cache-size=8192KiB doh-max-concurrent-queries=\
200 max-concurrent-queries=1000 max-concurrent-tcp-sessions=2000 servers=\
1.1.1.1 use-doh-server=https://cloudflare-dns.com/dns-query \
verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
CRS Config:
# 2025-09-11 09:11:49 by RouterOS 7.19.6
# software id = U4RC-4HII
# model = CRS326-24G-2S+
vlan-filtering=yes
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21 pvid=10
add bridge=bridge comment=defconf interface=ether22 pvid=10
add bridge=bridge comment=defconf interface=ether23 pvid=10
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge tagged=ether24 vlan-ids=1,10
add address=192.168.88.2/24 comment=defconf interface=bridge network=\
192.168.88.0
Hoping someone can have a look at my diagram and config to see if there's anything I've done wrong?
Thanks,
