vlan on bridge
Simple topology;
Conf Mikrotik x86 v7.5 ;
/interface vlan
add interface=bridge name=vlan1010 vlan-id=1010
add ingress-filtering=no name=bridge vlan-filtering=yes
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2,ether3 vlan-ids=1010
add address-pool=LAN_Pool disabled=yes interface=bridge name=DHCP
add address-pool=Guest_Poll interface=vlan1010 name=Guest
add address=10.0.10.0/24 dns-server=8.8.8.8 gateway=
10.0.10.1
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=
192.168.10.1
add address=XXX.XXX.XXX.XX comment=pubaddr interface=ether1 network=
XXX.XXX.XXX.XX
add address=192.168.10.1/24 comment=Default_LAN interface=bridge network=
192.168.10.0
add address=10.0.10.1/24 comment=vlan1010 interface=vlan1010 network=
10.0.10.0
Qnap and other devices cannot get ip from vlan1010. Where am i doing wrong ?
I don’t see the pools specified…is this your complete config?
Where am I doing wrong ?
Yet, you know what to show us ?
See the problem…
As per erlindens comment…
/export file=anynameyouwish ( minus router serial # and any public WANIP information )
I am sorry, I was thoughtless
add ingress-filtering=no name=Bridge_Local vlan-filtering=yes
set [ find default-name=ether3 ] disable-running-check=no name=ether1
set [ find default-name=ether1 ] disable-running-check=no name=ether2
set [ find default-name=ether2 ] disable-running-check=no disabled=yes name=\
    ether3
/interface vlan
add interface=Bridge_Local name=vlan1010 vlan-id=1010
add name=WAN
add name=LAN
/ip ipsec mode-config
set [ find default=yes ] src-address-list=local
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
    hash-algorithm=sha256 lifetime=8h nat-traversal=no
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=8h \
    name=IKE_Crypto nat-traversal=no
/ip ipsec peer
add address=28.XXX.XXX.XXX/32 local-address=21.XXX.XXX.XXX name=master \
    profile=IKE_Crypto
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc lifetime=1h pfs-group=\
    modp2048
add enc-algorithms=aes-256-cbc lifetime=1h name=IPSec_Crypto pfs-group=\
    modp2048
add name=LAN_Pool ranges=192.168.10.20-192.168.10.200
add name=Guest_Poll ranges=10.0.10.20-10.0.10.200
add address-pool=LAN_Pool disabled=yes interface=Bridge_Local name=DHCP_Local
add address-pool=Guest_Poll interface=vlan1010 name=DHCP_Guest
/port
set 0 baud-rate="(unknown)" name=serial0
set 1 name=serial1
add bridge=Bridge_Local interface=ether2
set discover-interface-list=none
/ip settings
set max-neighbor-entries=4096
/ipv6 settings
set max-neighbor-entries=2048
add bridge=Bridge_Local tagged=Bridge_Local,ether2 vlan-ids=1010
/interface detect-internet
set detect-interface-list=WAN
add interface=Bridge_Local list=LAN
add interface=ether1 list=WAN
add address=21.XXX.XXX.XXX comment=pubaddr interface=ether1 network=\
    21.XXX.XXX.XXX
add address=192.168.10.1/24 comment=Local_NET interface=Bridge_Local network=\
    192.168.10.0
add address=10.0.10.1/24 comment=vlan1010_NET interface=vlan1010 network=\
    10.0.10.0
/ip dhcp-relay
add dhcp-server=192.168.101.2 disabled=no interface=Bridge_Local \
    local-address=192.168.10.1 name=Local_NET_DHCP
add dhcp-server=192.168.101.2 interface=*11 local-address=10.0.10.1 name=\
    Gues_DHCP
add address=10.0.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=\
    10.0.10.1
add address=192.168.10.0/24 dns-server=192.168.200.5,192.168.200.6 gateway=\
    192.168.10.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=28.XXX.XXX.XXX list=Master_WAN
add address=192.168.100.0/23 list=Master_NET
add address=192.168.101.2 list=Master_DHCP
add address=192.168.10.0/24 list=Local_NET
add action=accept chain=input comment="Allow WinBox" dst-port=62321,8088 \
    protocol=tcp src-address-list=Master_NET
add action=accept chain=input comment="Allow DHCP" src-address-list=\
    Master_DHCP
add action=accept chain=input comment="IPSec Port" dst-port=500,1701,4500 \
    protocol=udp
add action=accept chain=input comment=Established,related,untracked \
    connection-state=established,related,untracked disabled=yes
add action=accept chain=input comment=ICMP disabled=yes protocol=icmp
add action=accept chain=input comment="Local loopback (for CAPsMAN)" \
    disabled=yes dst-address=127.0.0.1
add action=accept chain=input comment="Master to WAN" in-interface-list=WAN \
    src-address-list=Master_WAN
add action=drop chain=input comment=Invalid connection-state=invalid
add action=drop chain=input comment="All not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="In IPSec" ipsec-policy=in,ipsec
add action=accept chain=forward comment="Out IPSec" ipsec-policy=out,ipsec
add action=accept chain=forward comment="Established,related, untracked" \
add action=drop chain=forward comment=Invalid connection-state=invalid
add action=drop chain=forward comment="WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=reject chain=input comment="Anti Hack Exploit" content=user.dat \
    reject-with=icmp-network-unreachable
add action=drop chain=input comment="Anti Hack Exploit" content=user.dat
    "Memcrashed - Amplification Attacks UDP 11211" dst-port=11211 protocol=\
    udp
/ip firewall mangle
add action=mark-connection chain=forward comment=\
    "mark ipsec connections to exclude them from fasttrack" ipsec-policy=\
    out,ipsec new-connection-mark=ipsec passthrough=yes
    in,ipsec new-connection-mark=ipsec passthrough=yes
add action=accept chain=srcnat comment="Route Traffic" dst-address=0.0.0.0/0 \
    src-address-list=Local_NET
add action=masquerade chain=srcnat comment=Masquerade ipsec-policy=out,none \
    out-interface-list=WAN
/ip ipsec identity
add peer=master
/ip ipsec policy
add action=none dst-address=192.168.10.0/24 src-address=192.168.10.0/24
add action=none dst-address=10.0.10.0/24 src-address=10.0.10.0/24
add dst-address=0.0.0.0/0 level=unique peer=master proposal=IPSec_Crypto \
    src-address=192.168.10.0/24 tunnel=yes
    src-address=10.0.10.0/24 tunnel=yes
add disabled=no dst-address=0.0.0.0/0 gateway=21.XXX.XXX.XXX routing-table=\
    main suppress-hw-offload=no
add disabled=no dst-address=192.168.100.0/23 gateway=Bridge_Local \
    routing-table=main suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8088
set ssh disabled=yes
set api disabled=yes
set winbox port=62321
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Istanbul
/system hardware
set allow-x86-64=yes
/system identity
set name=On
/system ntp client
set enabled=yes
/system ntp client servers
/system scheduler
add disabled=yes interval=1h name=PubIP on-event=ReNewPubIP policy=\
    read,write,policy,test start-date=jan/01/1970 start-time=23:59:59
/system script
add dont-require-permissions=no name=ReNewPubIP owner=admin policy=\
    read,write,policy,test source=":local NewIP [/ip cloud get public-address]\
    \r\
    \n/ip address set [find where comment=\"pubaddr\"] address=\$NewIP network\
    =\$NewIP\r\
    \n/ip ipsec peer set master local-address=\$NewIP"
/tool mac-server
/tool mac-server ping
set enabled=no
add interface=vlan1010 list=LAN
Is the only thing I see at first glance that is missing…
+add interface=vlan1010 list=LAN
The problem continues..
My suggestion would be to configure ES48 port 47 as mirror port and start by mirroring port 48 to verify you are seeing the same thing there that you see with /tool sniffer on the Mikrotik x86 on ether2.
@Buckeye, @anav
:frowning: i found my mistake…
ESXi - Networking - Port Groups - Port_Name (which is used for lan) VLAN ID must be “4095”.. not “0”
All done now.. Thanks for help …
