VLAN problem… can anyone help??
I 've 3 vlan named 20,30,40 and 2 NIC … 1 for Local and another for Public.
whenever i gave 1 client pc to vlan 20’s ip … it is not working…
You need to post some more details on your config before anyone is going to be able to help you with anything more than guesswork.
Regards
Andrew
My out interface ip is : 10.0.20.6
in interface is: 192.168.100.1
I added 3 vlans
192.168.20.1/24 & 192.168.30.1/24 & 192.168.40.1/24
Now when i am using (client-side) ip range from vlan1 (192.168.20.2), then can’t ping & can’t access Internet. It is also for vlan2, vlan3.
But when i am using 192.168.100.2… then ok.
Can anyone give me solution?? with configurations…Pls!!!
Supply the results of the following please:
/interface vlan print
/ip address print
/ip route print
If you’re using NAT, then
/ip firewall nat print
as well.
Regards
Andrew
