I checked the generated .rsc and it closely matched what I have currently. I guess I'm on the right track ![]()
So I tried to setup guest WiFi, but the client device cannot acquire an IP address. I'm guessing the wifi2-guest interface cannot interact with the bridge VLAN?
/interface vlan
add comment=GUEST-WIFI interface=bridge name=vlan110 vlan-id=110
add comment=vlan110@VLAN-WAN-ONLY interface=vlan110 list=VLAN-WAN-ONLY
add comment=bridge-vlan110 interface=vlan110 list=LAN
add address=192.168.110.0/24 comment=bridge-vlan110 dns-server=192.168.110.1 gateway=192.168.110.1
add name=vlan110-pool ranges=192.168.110.10-192.168.110.200
add address=192.168.110.0/24 comment=bridge/vlan110 interface=vlan110 \
network=192.168.110.0
add address-pool=vlan110-pool comment=bridge-vlan110 interface=vlan110 name=\
vlan110-server
/interface wifi
add comment=GUEST configuration.mode=ap .ssid=\
MikroTik-XXXXXX disabled=no mac-address=XX:XX:XX:XX:XX:XX \
master-interface=wifi2 name=wifi2-guest security.authentication-types=\
wpa2-psk,wpa3-psk
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=wifi2-guest pvid=110
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=wifi2-guest vlan-ids=110
I tried allowing DHCP on the firewall, but I think it still cannot resolve the gateway (192.168.110.1) through ARP?
Here is my current firewall rules:
established,related,untracked
invalid log=yes
add action=drop chain=input comment="DROP DNS from WAN (tcp)" dst-port=53 \
in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="DROP DNS from WAN (udp)" dst-port=53 \
in-interface-list=WAN protocol=udp
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
in-interface=lo src-address=127.0.0.1
# -- BEGIN are these necessary?
add action=accept chain=input comment="accept DNS from LAN (tcp)" dst-port=53 \
in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="accept DNS from LAN (udp)" dst-port=53 \
in-interface-list=LAN protocol=udp
add action=accept chain=input comment="accept DHCP from LAN" dst-port=67,68 \
# -- END are these necessary?
# otherwise, only allow access from MGMT
add action=drop chain=input comment="DROP all not coming from MGMT" \
in-interface-list=!MGMT log=yes
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
"DROP isolated VLANs access to non-WAN interfaces" connection-state=\
!established in-interface-list=VLAN-WAN-ONLY log=yes out-interface-list=\
!WAN
Any help is very appreciated!
UPDATE: So I think I found why my guest wifi was not working. It was a typo in the /ip address section, should have specified address=192.168.110.1/24 but set address=192.168.110.0/24 instead. I also need to allow DNS in the firewall and remove the DHCP filters.
add address=192.168.110.1/24 comment=bridge/vlan110 interface=vlan110 \
