Hi All,
I am trying to connect a Mikrotik RouterOS and Cap together with multiple SSID's. What I have been able to do is create multiple bridges on the RouterOS for the specific subnets I need and I have the necessary firewall rules I require to keep them all separate. What I am struggling with is setting up multiple SSID's on the Cap and VLAN tag them trough a trunk to route them through the correct bridge on the Router. I am able to get the Wifi to connect though the router to the WAN and browse the internet, but it give a 192.168.0.x address and I am wanting it to be a 192.168.1.x address. Can someone tell me what I am missing with the VLAN setup? TIA
I have the Cap connected to the Router port ether24 from Cap port ether1
My Router Config:
add name=WAN
add name=LAN
add include=none name=LAN-IoT
add name=LAN-Internal
add name=LAN-Guest
add name=Trunk
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes interface-list=all
local-forwarding=no name=datapath_internal vlan-id=10 vlan-mode=use-tag
/caps-man configuration
add channel=channel11 country="united states" datapath=datapath_internal
datapath.bridge=bridge-Internal datapath.vlan-id=100 datapath.vlan-mode=
no-tag mode=ap name=Wireless_Internal security=Security_Internal ssid=
NutNutGoose
add channel=channel1 datapath=datapath_internal name=Wireless_Guest security=
Security_Guest ssid=Murphy-Guest
add name=dhcp-0.1 ranges=192.168.0.100-192.168.0.200
add name=dhcp-1.1 ranges=192.168.1.100-192.168.1.200
add name=dhcp-2.1 ranges=192.168.2.100-192.168.2.200
add name=dhcp-3.1 ranges=192.168.3.100-192.168.3.200
add add-arp=yes address-pool=dhcp-0.1 disabled=no interface=bridge
lease-time=1h name=dhcp
add add-arp=yes address-pool=dhcp-2.1 disabled=no interface=bridge-IoT name=
dchp-IoT
add add-arp=yes address-pool=dhcp-1.1 disabled=no interface=bridge-Internal
name=dhcp-Internal
add address-pool=dhcp-3.1 disabled=no interface=bridge-Guest name=dhcp-Guest
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge-Internal comment=defconf interface=ether3
add bridge=bridge-Internal comment=defconf interface=ether4
add bridge=bridge-Internal comment=defconf interface=ether5
add bridge=bridge-Internal comment=defconf interface=ether6
add bridge=bridge-Internal comment=defconf interface=ether7
add bridge=bridge-Internal comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge-IoT comment=defconf interface=ether17
add bridge=bridge-IoT comment=defconf interface=ether18
add bridge=bridge-IoT comment=defconf interface=ether19
add bridge=bridge-IoT comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge-Trunk comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge-Trunk interface=LAN-Internal pvid=100
add bridge=bridge-Trunk interface=LAN-IoT pvid=200
add bridge=bridge-Trunk interface=LAN-Guest pvid=300
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface bridge vlan
add bridge=bridge-IoT tagged=bridge-Internal,bridge-Guest untagged=bridge-IoT
vlan-ids=200
add bridge=bridge-Internal tagged=bridge-IoT,bridge-Guest untagged=
bridge-Internal vlan-ids=100
add bridge=bridge-Guest tagged=bridge-Internal,bridge-IoT untagged=
bridge-Guest vlan-ids=300
add bridge=bridge-Trunk comment="Reference from YouTube" disabled=yes tagged=
bridge-IoT untagged=bridge-Internal vlan-ids=100
add interface=bridge list=LAN
add interface=ether1 list=WAN
add interface=ether17 list=LAN-IoT
add interface=ether18 list=LAN-IoT
add interface=ether19 list=LAN-IoT
add interface=ether20 list=LAN-IoT
add interface=ether3 list=LAN-Internal
add interface=ether4 list=LAN-Internal
add interface=ether5 list=LAN-Internal
add interface=ether6 list=LAN-Internal
add interface=ether24 list=Trunk
add interface=sfp-sfpplus1 list=Trunk
add address=192.168.0.1/24 interface=ether2 network=192.168.0.0
add address=192.168.0.91 interface=ether24 network=192.168.0.0
add address=192.168.2.1/24 interface=ether17 network=192.168.2.0
add address=192.168.1.1/24 interface=ether3 network=192.168.1.0
add address=192.168.3.1/24 interface=bridge-Guest network=192.168.3.0
add address=192.168.100.1/24 interface=vlan100 network=192.168.100.0
add address=192.168.200.1/24 interface=vlan200 network=192.168.200.0
add address=192.168.250.1/24 interface=vlan300 network=192.168.250.0
add address=192.168.100.1 interface=bridge-Trunk network=192.168.10.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
netmask=24
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
netmask=24
add address=192.168.2.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.2.1
netmask=24
My Cap Config
add name=WAN
add name=LAN
add name=Wlan-Internal
add name=Wlan-Guest
add name=Wlan-IoT
add name=dhcp-10.1 ranges=192.168.10.10-192.168.10.100
add name=dhcp-20.1 ranges=192.168.20.10-192.168.20.100
add name=dhcp-30.1 ranges=192.168.30.10-192.168.30.50
add add-arp=yes address-pool=dhcp-10.1 disabled=no interface=
bridge-Wlan-Internal name=dhcp-Wlan-Internal
add add-arp=yes address-pool=dhcp-20.1 disabled=no interface=bridge-Wlan-IoT
name=dhcp-Wlan-IoT
add address-pool=dhcp-30.1 disabled=no interface=bridge-Wlan-Guest name=
"dhcp=Wlan-Guest"
add bridge=bridge-Trunk comment=defconf interface=ether1
add bridge=bridge-Trunk comment=defconf interface=ether2
add bridge=bridge-Trunk comment=defconf interface=wlan1
add bridge=bridge-Trunk comment=defconf interface=wlan2
add bridge=bridge-Trunk interface=Wlan-Internal pvid=100
add bridge=bridge-Trunk interface=Wlan-IoT pvid=200
add bridge=bridge-Trunk interface=Wlan-Guest pvid=300
add bridge=bridge-Wlan-Guest tagged=bridge-Wlan-Internal,bridge-Wlan-IoT
untagged=bridge-Wlan-Guest vlan-ids=300
add bridge=bridge-Wlan-Internal tagged=bridge-Wlan-Guest,bridge-Wlan-IoT
untagged=bridge-Wlan-Internal vlan-ids=100
add bridge=bridge-Wlan-IoT tagged=bridge-Wlan-Internal,bridge-Wlan-Guest
untagged=bridge-Wlan-IoT vlan-ids=200
add bridge=bridge-Trunk untagged=ether1 vlan-ids=""
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=
LAN wan-interface-list=WAN
add disabled=yes interface=ether2 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridge-Trunk discovery-interfaces=ether1,bridge-Trunk enabled=yes
interfaces=wlan1,wlan2
add address=192.168.10.1/24 interface=bridge-Wlan-Internal network=192.168.10.0
add address=192.168.20.1/24 interface=bridge-Wlan-IoT network=192.168.20.0
add address=192.168.30.1/24 interface=bridge-Wlan-Guest network=192.168.30.0
add address=192.168.100.2/24 interface=vlan100 network=192.168.100.0
add address=192.168.200.2/24 interface=vlan200 network=192.168.200.0
add address=192.168.250.2/24 interface=vlan300 network=192.168.250.0
add address=192.168.100.2 disabled=yes interface=vlan100 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
bridge-Trunk
/ip dhcp-relay
add dhcp-server=192.168.0.1 disabled=no interface=bridge-Trunk name=relay1
add dhcp-server=192.168.2.1 disabled=no name=relay2
add address=192.168.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.10.1
netmask=24
add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1
netmask=24
