VLAN to LAN routing
Initial setup:
 /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU
 0  R  WAN                                 ether            1500  1598
 1  RS ether2                              ether            1500  1598
 2  RS ether3                              ether            1500  1598
 3   S ether4                              ether            1500  1598
 4   S ether5                              ether            1500  1598
 5  RS ether6                              ether            1500  1598
 6   S ether7                              ether            1500  1598
 7   S ether8                              ether            1500  1598
 8   S ether9                              ether            1500  1598
 9   S ether10                             ether            1500  1598
10     sfp1                                ether            1500  1598
11  R  B-LAN                               bridge           1500  1598
12  R  BT-Internet                         pppoe-out        1480
13  RS LAG1                                bond             1500
14   S LAG2                                bond             1500
15  R  VL-USR-Deployment                   vlan             1500  1594
16  R  VL-USR-Guest                        vlan             1500  1594
17  R  VL-USR-Office-LAN                   vlan             1500  1594
18  R  VL-USR-Office-WLAN                  vlan             1500  1594
19  R  vlan1-TEST                          vlan             1500  1594
 /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0 D 81.133.92.199/32   81.130.224.1    BT-Internet
 1   10.40.1.1/24       10.40.1.0       B-LAN
 2   10.20.10.1/24      10.20.10.0      vlan1-TEST
 3   10.20.1.1/24       10.20.1.0       VL-USR-Office-LAN
 4   10.20.3.1/24       10.20.3.0       VL-USR-Deployment
 5   10.20.6.1/24       10.20.6.0       VL-USR-Guest
 6   10.20.2.1/24       10.20.2.0       VL-USR-Office-WLAN
Problem - I can ping one VALN from another one but can’t ping 10.40.1.1/24 10.40.1.0 B-LAN from any VLAN
From 10.40.1.0 I can ping pc’s in VLANS
OK - my fault!
Realized that tp-link switch was on VLAN1 but with IP of LAN.
PC connected to LAN had incorrect static IP matching switch.
