I’m really struggling to work out how to implement the attached VLAN setup:
Essentially I’m need to take any VLANS i receive on one port on a CRS317 and send them to a CCR1009 and send them all out a seperate port. I realise this is Q-in-Q which I can use, however, I dont always know which VLANs I may or may not receive.
I need to just be able to accept ANY VLAN on CRS317 SFP-SFPPLUS2, send it across to CCR1009 and out ETHER1 without manually configuring each one.
Is CRS317 SFP-SFPPLUS1 and CRS317 SFP-SFPPLUS2 bridged together? Is CCR1009 SFP-SFPPLUS1 and CCR1009 ETHER1 bridged together?
If not then, talking about VLANs makes no sense. You only create VLAN trunks between two switches or between a router and a switch, but never between two routers.
What you need to do is route the traffic over the linknet.
It will help if you show an export of your interface and IP-address configs.
