CRS125
Try to do according thia article http://wiki.mikrotik.com/wiki/Manual:CRS_examples
There wasn’t any mac at connecting device.
After that try to do like this
/interface vlan
add interface=ether2-master-local l2mtu=1584 name=vlan111 vlan-id=111
add interface=ether2-master-local l2mtu=1584 name=vlan222 vlan-id=222
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether2-master-local,switch1-cpu vlan-id=111
add tagged-ports=ether2-master-local,switch1-cpu vlan-id=222
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=222 ports=ether3-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether4-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether5-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether6-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether7-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether8-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether9-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether10-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether11-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether12-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether13-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether14-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether15-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether16-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether17-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether18-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether19-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether20-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether21-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether22-slave-local sa-learning=yes
add new-customer-vid=222 ports=ether23-slave-local sa-learning=yes
add new-customer-vid=111 ports=ether24-slave-local sa-learning=yes
add address=192.168.128.62/26 interface=vlan222 network=192.168.128.0
just put my vlan and ip
ip
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 10.125.125.60/24 10.125.125.0 vlan92
[admin@MikroTik] >
1 and 2 port - trunk
[admin@MikroTik] /interface ethernet switch egress-vlan-tag> print
# VLAN-ID TAGGED-PORTS
0 D 4095
1 40 ether1
ether2
switch1-cpu
2 58 ether1
ether2
switch1-cpu
3 92 ether1
ether2
switch1-cpu
interfaces
[admin@MikroTik] > interface print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 ether1 ether 1500 1588 4064
1 R ether2 ether 1500 1588 4064
2 S ether3 ether 1500 1588 4064
3 S ether4 ether 1500 1588 4064
4 S ether5 ether 1500 1588 4064
5 ether6 ether 1500 1588 4064
6 ether7 ether 1500 1588 4064
7 ether8 ether 1500 1588 4064
8 ether9 ether 1500 1588 4064
9 ether10 ether 1500 1588 4064
10 RS ether11 ether 1500 1588 4064
11 RS ether12 ether 1500 1588 4064
12 ether13 ether 1500 1588 4064
13 ether14 ether 1500 1588 4064
14 ether15 ether 1500 1588 4064
15 ether16 ether 1500 1588 4064
16 ether17 ether 1500 1588 4064
17 ether18 ether 1500 1588 4064
18 ether19 ether 1500 1588 4064
19 ether20 ether 1500 1588 4064
20 ether21 ether 1500 1588 4064
21 ether22 ether 1500 1588 4064
22 ether23 ether 1500 1588 4064
23 ether24 ether 1500 1588 4064
24 sfp1 ether 1500 1588 4064
25 R br-vlan92 bridge 1500 1584
26 R vlan40 vlan 1500 1584
27 R vlan58 vlan 1500 1584
28 RS vlan92 vlan 1500 1584
vlans
[admin@MikroTik] > interface ethernet switch vlan print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 D 4095 ether1 no no no no none
ether6
ether7
ether8
ether9
ether10
ether11
ether12
ether13
ether14
ether15
ether16
ether17
ether18
ether19
ether20
ether21
ether22
ether23
ether24
sfp1
switch1-cpu
1 40 ether3 no yes no no none
2 58 ether4 no yes no no none
3 92 ether11 no yes no no none
ether12
[admin@MikroTik] >
[admin@MikroTik] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether11 br-vlan92 0x80 10 none
1 ether12 br-vlan92 0x80 10 none
2 vlan92 br-vlan92 0x80 10 none
[admin@MikroTik] >
[admin@MikroTik] >
the same thing - no mac on connecting device
macs on CRS according vlans in the trunk
