I have recently gotten a hEX S (RB760iGS) that I want to use to segment my network into vlans. I have not finished all the vlans and stuff in the router config, but I cannot get this configuration to work either…
My problem right now is that I cannot get the DHCP on access ports to work (I don’t have the switch and server here now, as I am studying elsewhere). But I have tried testing it in eve-ng with CHR, and it seems to work there with the same config. So I don’t really understand what I am doing wrong here. I am guessing that my config will do a better job at explaining than me '![]()
If anyone does have any tips or ideas on how to make this work, it would be very much appreciated!
Thanks in advance!
This is how I have planned the network (probably not optimal, so suggestions are welcome :)), all vm’s either have its own dedicated NIC, or have vlan aware virtual nics.
The current config on the router:
# jan/02/1970 03:52:42 by RouterOS 6.47.7
# software id = 6JIK-BB6Q
# model = RB760iGS
# serial number = D4500D910DB4
add admin-mac=08:55:31:85:A2:2E auto-mac=no comment=defconf name=bridge
add fast-forward=no name=vlan-bridge pvid=30 vlan-filtering=yes
/interface vlan
add comment=Management interface=vlan-bridge name=VLAN10 vlan-id=10
add comment=Management/BMC interface=vlan-bridge name=VLAN11 vlan-id=11
add comment="Remote Access" interface=vlan-bridge name=VLAN20 vlan-id=20
add comment=Devices interface=vlan-bridge name=VLAN30 vlan-id=30
add comment=Storage interface=vlan-bridge name=VLAN100 vlan-id=100
add comment=Auth interface=vlan-bridge name=VLAN110 vlan-id=110
add comment=DMZ interface=vlan-bridge name=VLAN120 vlan-id=120
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=VLAN30-POOL ranges=10.11.30.50-10.11.30.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=VLAN30-POOL disabled=no interface=VLAN30 name=VLAN30-DHCP
add bridge=vlan-bridge comment=defconf interface=ether4 pvid=30 tag-stacking=yes
add bridge=bridge comment=defconf interface=sfp1
add bridge=vlan-bridge comment=defconf hw=no interface=ether3 pvid=30 tag-stacking=yes
/interface bridge settings
set allow-fast-path=no
/interface bridge vlan
add bridge=vlan-bridge tagged=vlan-bridge untagged=ether3,ether4 vlan-ids=30
add interface=vlan-bridge list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.11.30.1/24 interface=VLAN30 network=10.11.30.0
add address=10.11.10.1/24 interface=VLAN10 network=10.11.10.0
add address=10.11.11.1/24 interface=VLAN11 network=10.11.11.0
add address=10.11.20.1/24 interface=VLAN20 network=10.11.20.0
add address=10.11.100.1/24 interface=VLAN100 network=10.11.100.0
add address=10.11.110.1/24 interface=VLAN110 network=10.11.110.0
add address=10.11.120.1/24 interface=VLAN120 network=10.11.120.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=\
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new disabled=yes in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
(Just tell me if I have explained something poorly '
