vlans not working
Following example https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#VLAN_Example_.231_.28Trunk_and_Access_Ports.29
# model = RB760iGS
add name=uplink-bridge vlan-filtering=yes
add bridge=uplink-bridge interface=sfp1
add bridge=uplink-bridge interface=ether3 pvid=200
add bridge=uplink-bridge interface=ether1 pvid=613
/interface bridge vlan
add bridge=uplink-bridge tagged=sfp1 untagged=ether3 vlan-ids=200
add bridge=uplink-bridge tagged=sfp1 untagged=ether1 vlan-ids=613
[admin@gp-gw-new] /interface bridge<SAFE> /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.88.1/24    192.168.88.0    ether5
 1   207.55.104.250/24  207.55.104.0    ether3
However, while running /ping 207.55.104.1, tshark shows the packets coming out sfp1 as untagged:
Frame 30: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
    Interface id: 0 (en7)
        Interface name: en7
    Encapsulation type: Ethernet (1)
    Arrival Time: Oct  6, 2021 11:21:50.550736000 PDT
    [Time shift for this packet: 0.000000000 seconds]
    Epoch Time: 1633544510.550736000 seconds
    [Time delta from previous captured frame: 0.999969000 seconds]
    [Time delta from previous displayed frame: 0.999969000 seconds]
    [Time since reference or first frame: 686.323255000 seconds]
    Frame Number: 30
    Frame Length: 60 bytes (480 bits)
    Capture Length: 60 bytes (480 bits)
    [Frame is marked: False]
    [Frame is ignored: False]
    [Protocols in frame: eth:ethertype:arp]
Ethernet II, Src: b8:69:f4:86:47:4f, Dst: ff:ff:ff:ff:ff:ff
    Destination: ff:ff:ff:ff:ff:ff
        Address: ff:ff:ff:ff:ff:ff
        .... ..1. .... .... .... .... = LG bit: Locally administered address (this is NOT the factory default)
        .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)
    Source: b8:69:f4:86:47:4f
        Address: b8:69:f4:86:47:4f
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
    Type: ARP (0x0806)
    Padding: 000000000000000000000000000000000000
Address Resolution Protocol (request)
    Hardware type: Ethernet (1)
    Protocol type: IPv4 (0x0800)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
    Sender MAC address: b8:69:f4:86:47:4f
    Sender IP address: 207.55.104.250
    Target MAC address: 00:00:00:00:00:00
    Target IP address: 207.55.104.1
IP Address should be attached to Vlan interface, not ether interface
Missing.
Optional
add bridge=uplink-bridge interface=sfp1 ingress-filtering=yes frame-types=admit-only-vlan-tagged
add bridge=uplink-bridge interface=ether3 pvid=200 ingress-filtering=yes frame-type=admit-only-untagged-and-prority-tagged
add bridge=uplink-bridge interface=ether1 pvid=613 ingress-filtering=yes frame-type=admit-only-untagged-and-priority-tagged
add bridge=uplink-bridge tagged=uplink-bridge,sfp1 untagged=ether3 vlan-ids=200
add bridge=uplink-bridge tagged=uplink-bridge,sfp1 untagged=ether1 vlan-ids=613
For future reference and guidance read this bible…
That did not fix it…
Then post the complete config.
vlan200 is the primary routed uplink for the router
vlan613 is a layer 2 vlan to elsewhere for cust 2
diagram attached
Note, this config is done per https://help.mikrotik.com/docs/display/ROS/Bridge+VLAN+Table#BridgeVLANTable-Trunk/Accessportsetup
# jan/01/1970 16:17:06 by RouterOS 6.46.7
# software id = G0ZP-8CHD
# model = RB760iGS
set [ find default-name=ether1 ] comment="Customer 1 Handoff"
set [ find default-name=ether2 ] comment="Customer 2 Handoff"
set [ find default-name=ether3 ] comment="Dummy vlan200 interface"
set [ find default-name=ether5 ] comment="Local Access"
set [ find default-name=sfp1 ] comment="Uplink"
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=uplink-bridge interface=ether2 pvid=613
add bridge=uplink-bridge tagged=sfp1 untagged=ether2 vlan-ids=613
add address=192.168.88.1/24 comment=defconf interface=ether5 network=\
    192.168.88.0
add address=10.55.104.250/24 interface=ether3 network=10.55.104.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=<addresses> list=allowed_to_router
add action=accept chain=input comment="Allowed from PEAK" src-address-list=\
    allowed_to_router
add action=accept chain=input comment="Allow established and related" \
add action=drop chain=input comment="Block input from anywhere else"
add action=jump chain=forward jump-target=suspended src-address-list=\
    suspended
add action=accept chain=suspended dst-port=53 protocol=tcp
add action=accept chain=suspended dst-port=53 protocol=udp
add action=drop chain=suspended
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=<addresses>
set ssh address=<addresses>
set api address=<addresses>
set winbox address=<addresses>
set api-ssl address=<addresses>
/snmp
set contact=Engineering enabled=yes location=Here
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=vlan-new
/system package update
set channel=long-term
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
vlan-example.pdf (22.3 KB)
You dont define the vlans??
They should have number and name and interface being the bridge.
You still havent fixed your /interface bridge vlan as provided.
Where are your firewall rules or does this not face the internet (aka an ISP)
What is ether3 doing with an IP address.
Not much makes sense to me.
Is this mostly a cut and paste job from youtube??
At the moment this is a lab router; I’m just trying to get vlan tagging to work following the instructions in mikrotik url I gave.
I removed the uplink-bridge from the tagged clause as it didn’t change anything
sorry, I forgot to update the diagram with ether 3, when I used vlans, it didn’t send packets out sfp1 at all
Here’s the correct diagram:
vlan-example-ether3.pdf (23.5 KB)
Setup your lab according to this guide, not the internet crap..
“The internet crap” is mikrotik’s official documentation :wink: but I’ll check out your link…
Haha too funny, yes that is their old crap, they have better info now…
https://help.mikrotik.com/docs/display/ROS/VLAN
All three docs (old, new, forum) say basically the same thing. In the end, the issue was mixing layer2/3 just doesn’t seem to work and I solved the problem by using two hexes, one as a switch and one as a router.
