Thanks @nichky. I tried the link, but while that helped me understand vlans more it didn’t really address my situation.
So I asked ChatGPT for a suggestion to create a guest vlan on an already existing network, trunked from router to access point. Here’s what it came up with…
To configure a MikroTik router for a guest VLAN with the subnet 10.10.10.0/24 and VLAN ID 20, where this VLAN will be trunked to an external access point, follow these steps:
- Create the VLAN interface on the MikroTik Router:
This will define VLAN ID 20 on the physical interface that connects to the external access point (for example, ether1).
Steps:
Go to Interfaces → VLAN and add a new VLAN.
VLAN ID: 20
Interface: ether1 (or whatever interface connects to the access point)
MTU: Leave as default (typically 1500)
You can create it using the following CLI command:
csharp
Copy code
/interface vlan add name=guest_vlan20 vlan-id=20 interface=ether1
- Assign IP Address to the VLAN Interface:
Next, assign the IP address 10.10.10.1/24 to the newly created VLAN interface. This will serve as the default gateway for devices in the guest VLAN.
Steps:
Go to IP → Addresses and add the IP address.
Address: 10.10.10.1/24
Interface: guest_vlan20
Or using the CLI:
csharp
Copy code
/ip address add address=10.10.10.1/24 interface=guest_vlan20
- Set Up DHCP Server (Optional, for automatic IP assignment):
If you want to assign IP addresses dynamically to devices in the guest VLAN, you can configure a DHCP server.
Steps:
Go to IP → DHCP Server and click Add.
Address Pool: guest_pool
Gateway: 10.10.10.1 (the router’s address in this VLAN)
DNS Server: (optional) You can use a public DNS server, e.g., 8.8.8.8.
You will also need to create a DHCP Pool:
bash
Copy code
/ip pool add name=guest_pool ranges=10.10.10.2-10.10.10.254
Finally, add the DHCP Server:
csharp
Copy code
/ip dhcp-server add name=guest_vlan20_dhcp interface=guest_vlan20 address-pool=guest_pool disabled=no
- Create Firewall Rules to Isolate the Guest VLAN (Optional):
If you want to isolate guest users from your internal network, create firewall rules to block traffic between the guest VLAN and your internal network.
Example: Block traffic from the guest VLAN to the internal LAN:
Go to IP → Firewall → Filter Rules and click Add.
Chain: forward
Src. Address: 10.10.10.0/24
Dst. Address: 192.168.0.0/24 (example internal subnet)
Action: drop
Or use the CLI:
css
Copy code
/ip firewall filter add chain=forward src-address=10.10.10.0/24 dst-address=192.168.0.0/24 action=drop
Configure the Access Point to Tag VLAN 20:
On the external access point, you need to ensure the VLAN tag 20 is properly assigned to the guest network. The exact steps depend on your access point model, but typically, you will:
Set the VLAN tag for the guest network to 20 on the access point.
Set the access point to operate in 802.1q trunking mode for the interface connecting to the MikroTik router (or configure the SSID to tag the traffic with VLAN 20).
Test Connectivity:
Connect a device to the access point.
Ensure it gets an IP in the 10.10.10.0/24 range, and check if it can reach the gateway 10.10.10.1 (the MikroTik router).
Verify that the device in the guest VLAN cannot access other networks (depending on your firewall rules).
Summary Configuration Overview:
VLAN ID: 20
Subnet: 10.10.10.0/24
Router IP (Gateway): 10.10.10.1
DHCP Range: 10.10.10.2 - 10.10.10.254
Firewall Rule: Block access to internal network (192.168.x.x) from the guest VLAN (10.10.10.x).
CLI Configuration:
bash
Copy code
This should set up your MikroTik router to properly handle the guest VLAN traffic, provide IP addresses to connected clients, and optionally isolate the guest network from the rest of your internal network.
I’d really appreciate it if someone could check it out and offer thoughts as to how well it might work please.
Would I be right in assuming the dst-address in the filter firewall setting would be 192.168.1.0/24 (rather than 192.168.0.0/24) if that was the home network subnet?
I could give it a go but we’re on the road atm and it’s my home network router with a custom config that I’d rather not tamper with if possible.
Thanks again for all your help.
