hola buenos días quien me puede ayudar necesito pasar varias vlans por un mismo puerto dichas vlans ya
están entrando por un puerto troncar tengo un ccr 1036
saludos
hello good morning who can help me I need to pass several vlans through the same port said vlans already
they are entering through a trunk port I have a 1036 ccr
Pass them where? You’ve described only one end of the “passage”, the trunk port; do you want to pass each of the VLANs to its individual access port, or to another trunk port, or do you want your CCR to act as a router for the subnet in each VLAN…? Have you seen the @pcunite’s tutorial on VLANs?
If you do just this, all VLANs will be forwarded betewen sfp1 and ether1.
If you want only permitted VLANs to be forwarded, you have to configure and activate VLAN filtering: /interface bridge vlan
add vlan-ids=1 bridge=bridge-for-vlans untagged=sfp1,ether1,bridge-for-vlans
add vlan-ids=2,3 bridge=bridge-for-vlans tagged=sfp1,ether1,bridge-for-vlans
/interface bridge set bridge-for-vlans vlan-filtering=yes
You only have to add bridge-for-vlans into the tagged or untagged list of you want to place an IP address of the Mikrotik itself into the VLAN.
Only one VLAN can be untagged on each interface, so whenever the untagged list of some row in the /interface bridge vlan table is not empty, that row’s vlan-ids list must contain exactly one VLAN ID.
VLAN 1 is handled as untagged in default settings of most other vendors’ switches. Also for the virtual port representing the bridge to the rest of the the network stack and for the rows in /interface bridge port, the default value of parameter pvid is 1. You can set the pvid to any other VID between 1 and 4094, but there is no way to set the pvid parameter to none.
If you want to attach a local IP configuration to a VLAN which is tagged on the virtual port representing the bridge, you need to /interface vlan add vlan-id=X interface=bridge-for-vlan name=some-nice-name and then link the /ip address configuration to interface=some-nice-name. If you want to attach a local IP configuration to a VLAN which is tagless on the virtual port representing the bridge, link it directly to the bridge (interface=bridge-for-vlan).
From your configuration I can see that you have VLAN 950 tagged on sfp2 and untagged on ether6 and ether7, and VLAN 12 tagged on sfp2 and untagged on ether4. This is the old way of configuring VLAN filtering, where you had one bridge per each VLAN (in your case, bridge12 and bridge950) and you needed the same number of /interface vlan as the number of ports on which the VLAN is tagged. So to change the ether7 to a tagged port for VLAN 950 and adding a tagged VLAN 12 to it without redoing your configuration completely to the new way, you have to
If you don’t mind to keep VLAN 950 tagless on ether7, just skip all the first three steps (related to bridge950) above, but in that case, the equipment connected to ether7 must be configured the same way (VLAN 950 tagless on the wire, VLAN 12 tagged).
Yes, sure. A frame tagged with VID 950 comes to sfp2, where it is matched and processed by the tagged side of “your” existing /interface vlan named “vlan950”. The tagless end of this interface is a member port of bridge950. “My” /interface vlan named “ether7.950” takes this untagged frame from bridge950, tags it with VID 950 and sends it out tagged via ether7. The same will happen with incoming frames tagged with VID 12, except that they will travel between sfp2 and ether7 through a different pair of /interface vlan and a different bridge.
Maybe I did not understand you well and you actually want to make ether7 an access port to both VLANs, 12 and 950? It is technically possible but there is a number of good reasons not to do that. Is that what you really want?
In that case, just do what I suggested in post #6 (just fixed the commands, sorry for missing “port”). If something doesn’t work, post an export taken after those changes were made.
Sorry, believe me you don’t want to read my direct writing in Spanish
