VPLS over PPPoE
Hi
Has anyone been able to get VPLS working over a PPPoE connection? The VPLS tunnel is running , but I cannot seem to bridge the 2 CPE’s. Cant even ping across the VPLS tunnel. Any help will be appreciated
mtu problems?
I am not sure. I have set MPLS mtu to 1522 and tried on 1512. However I have done a vpls tunnel between a highsite and an interconnect with a pppoe access concentrator and was working fine. I just cant get the obove working. Will wait for an answer from support.
There is an option for MPLS over PPP that you need to enable in the PPP profile.
That has been enabled.
Could you post relevant config?
