VPN and Dns Suffix
when client connects to Mikrotik by VPN is there a way to pass [Dns Suffix] property?
Under /ppp profile I see only dns-server option but no domin/dns suffix property
Also I haven’t saw option to pass DHCP to VPN clients.
I’m mentioning this because there I can see /ip dhcp-server network domain option and that is working fine inside local network.
Does anyone have some suggestion/solution/steps how to achieve this?
Regards,
Darko Bazulj
It is not supported.. You can add it on client side manualy.
More on this topic:
http://forum.mikrotik.com/t/dns-problem-for-incomming-vpn-users/36103/1
@huntah thank you for the link.
I have used rras/isa/tmg and that was never a problem until I switched to mikrotik :frowning:
Missing NetBIOS broadcast is another problem.
Now I know I can suggest mikrotik only to smaller offices where is feasible to manually setup remote clients.
Regards,
Darko Bazulj
