VPN client can't reach main network
Hi all, i’m new with MikroTik rOS.
I create OpenVPN with MikroTik, the connection is ok, but i can’t reach anything in my LAN.
We have a core switch (ip: 172.16.100.1), we have many subnets (192.168.1.0; 2.0; 4.0; 7.0; etc…).
MikroTik route all subnet in core switch. All VLAN defining in the core switch.
OpenVPN pool: 172.16.1.0/24. How to route all ovpn request in MikroTik to my main network (192.168.1.0)?
The ovpn clients only need the main network reach.
Thx,
R.
Hello!
I think you will need the following:
  • Add the route to 192.168.1.0/24 in the VPN client config files
  • Add a route in the Mikrotik router for 192.168.1.0/24 (192.168.1.0/24 as destination, 172.16.100.1 as gateway). I undestand you already had this
  • Add a route in the Core switch to reach the VPN client network through the Mikrotik router (For the way back)-
Regards,
Damián
