VPN for Android devices
Hello everyone
I’m trying to setup a VPN for android devices with routeros v6.41.3 but no luck so far. First I tried with pptp but nothing, then somebody recommended me to use L2TP which sounds good but with no luck either. I’ve been testing every working settings from internet but none works for me and I can’t see the error in the log, maybe someone can help me. This is what I get from logs:
PD: Any solution it’s ok for me, I just need a working VPN for test purposes.
15:06:22 l2tp,debug,packet rcvd control message from 10.0.0.15:64524 to 10.0.0.1:1701
15:06:22 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
15:06:22 l2tp,debug,packet     (M) Message-Type=SCCRQ
15:06:22 l2tp,debug,packet     (M) Protocol-Version=0x01:00
15:06:22 l2tp,debug,packet     (M) Host-Name="anonymous"
15:06:22 l2tp,debug,packet     (M) Framing-Capabilities=0x3
15:06:22 l2tp,debug,packet     (M) Assigned-Tunnel-ID=52383
15:06:22 l2tp,debug,packet     (M) Receive-Window-Size=1
15:06:22 l2tp,info first L2TP UDP packet received from 10.0.0.15
15:06:22 l2tp,debug tunnel 65 entering state: wait-ctl-conn
15:06:22 l2tp,debug,packet sent control message to 10.0.0.15:64524 from 10.0.0.1:1701
15:06:22 l2tp,debug,packet     tunnel-id=52383, session-id=0, ns=0, nr=1
15:06:22 l2tp,debug,packet     (M) Message-Type=SCCRP
15:06:22 l2tp,debug,packet     (M) Framing-Capabilities=0x1
15:06:22 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
15:06:22 l2tp,debug,packet     Firmware-Revision=0x1
15:06:22 l2tp,debug,packet     (M) Host-Name="zeus1"
15:06:22 l2tp,debug,packet     Vendor-Name="MikroTik"
15:06:22 l2tp,debug,packet     (M) Assigned-Tunnel-ID=65
15:06:22 l2tp,debug,packet     (M) Receive-Window-Size=4
15:06:22 l2tp,debug,packet     tunnel-id=65, session-id=0, ns=1, nr=1
15:06:22 l2tp,debug,packet     (M) Message-Type=SCCCN
15:06:22 l2tp,debug tunnel 65 entering state: estabilished
15:06:22 l2tp,debug,packet sent control message (ack) to 10.0.0.15:64524 from 10.0.0.1:1701
15:06:22 l2tp,debug,packet     tunnel-id=52383, session-id=0, ns=1, nr=2
15:06:22 l2tp,debug,packet     tunnel-id=65, session-id=0, ns=2, nr=1
15:06:22 l2tp,debug,packet     (M) Message-Type=StopCCN
15:06:22 l2tp,debug,packet     (M) Result-Code=6
15:06:22 l2tp,debug,packet     tunnel-id=52383, session-id=0, ns=1, nr=3
15:06:22 l2tp,debug tunnel 65 entering state: dead
Well, I made it works with windows but android keep failing with the same logs messages.
I solved with SSTP.
