VPN for Mikrotik for game Mobile legend
iam from indonesia, playing mobile legend is my hobby. sometimes its getting lag with my ISP. does anyone sell VPN mikrotik L2tp/pptp for mobile legend ?
for more information maybe i need VPN Tunnel dedicated 1:1 server singpore. its better if you have trial. Thanks
no answer at all ?
I’m afraid a VPN tunnel won’t solve any lag or high latency, it will most likely introduce more.
so do you have solution for this?
Not sure if you know anything about networking.
Just get a VPN subscription from a VPN provider, like NordVPN. See if it fixes the issue.
Yes, you can use a VPN for accessing from the nearest country server but remember VPN cannot reduce your lag because it depends on your ping rate.
Depends on your ISP, ML IIRC uses AWS. Many ISPs aren’t peered with AWS. A VPN provider may fix the latency, only if the latency from your ISP to said VPN is low + VPN host is peered with AWS via their own upstream provider. A lot of factors are involved.
Just ask your ISP to peer with AWS instead.
can u tell me how to get AWS vpn for mikrotik for game mobile legend, i want to buy
i already use AWS CHR EC2 but mobile legend is still lagging, does anyone know ho to fix this?l
Move to another location in your country with high speed wired internet.
