VPN & Port forward through 1 Interface
Hello MK Community.
Currently I have 2 ISPs, (ISP1 - higher bandwidth & private IP, ISP2 - Lower bandwidth and Dynamic public IP).
With that being said, I have already set up Failover configuration using ISP1 as primary and ISP2 as secondary.
Expected behaviour
Having the failover configuration, would like to set up a Wireguard VPN and Port forwarding ONLY using ISP2.
Actual behaviour
When ISP1 is up, there is no packet responses. As soon as there is not ISP1 set as priority everything works, I did the PF and works, Wireguard VPN works.
add admin-mac= auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] loop-protect=off
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/disk
set usb1 type=hardware
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=23h59m59s name=\
    defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=sfp1
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
add interface=wireguard1 list=LAN
add interface=*9 list=WAN
add interface=*A list=WAN
/interface wireguard peers
add allowed-address=10.20.1.2/32 interface=wireguard1 public-key=\
    "VnTNWEPEIGe4ehffWqtG8GdIb+HKxcpSvACRekuVa1I="
add allowed-address=10.20.1.3/32 interface=wireguard1 public-key=\
    "D2bLdRCWi8QS/xznIUHNzufVZOpwX2pVdnf+0WcNr1k="
    192.168.88.0
add address=10.20.1.1/24 interface=wireguard1 network=10.20.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.252 client-id=1:d8:32:14:e4:1c:88 mac-address=\
    D8:32:14:E4:1C:88 server=defconf
add address=192.168.88.247 mac-address=08:00:27:A1:50:F7 server=defconf
add address=192.168.88.253 client-id=1:90:61:ae:16:b0:1b mac-address=\
    90:61:AE:16:B0:1B server=defconf
add address=192.168.88.251 client-id=1:3c:19:cb:6e:7:2f mac-address=\
    3C:19:CB:6E:07:2F server=defconf
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=192.168.0.0/16 list=Access
add address=190.0.0.0/8 list=Access
add address=186.0.0.0/8 list=Access
add address=200.0.0.0/8 list=Access
add action=reject chain=forward dst-address-list=Ads protocol=tcp reject-with=icmp-network-unreachable src-address-list=Access
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
    protocol=udp
add action=accept chain=input comment="allow WireGuard traffic" src-address=\
    10.20.1.0/24
add action=accept chain=input in-interface=ether2 src-address-list=Access
    established,related,untracked
    invalid disabled=yes
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=23000 in-interface=ether1 protocol=\
    tcp to-addresses=192.168.88.252 to-ports=80
add action=dst-nat chain=dstnat dst-port=24000 in-interface=ether1 protocol=\
    tcp to-addresses=192.168.88.247 to-ports=443
add action=dst-nat chain=dstnat dst-port=25000 in-interface=ether1 protocol=\
    udp to-addresses=192.168.88.247 to-ports=5060
add action=dst-nat chain=dstnat disabled=yes dst-port=10000-20000 \
    in-interface=ether1 protocol=udp to-addresses=192.168.88.247 to-ports=\
    10000-20000
Thank you
Hi there, yes there is a bug in Wireguard firmware, which prevents success using Wireguard on WAN2, when WAN1 is primary.
We can fix that with some trickery.
A quick perusal of your config also shows that you have other issues that need to be addressed first.
a. you are port forwarding on ether1, HOW? If you cannot use ether1 because its a private IP for wireguard, equally you cannot use ether1 for port forwarding.
b. You have other issues with WANs ( I dont see a working WAN2 ) and see errors..
add interface=9 list=WAN
add interface
*=A* list=WAN
Until we get to the truth about requirements not worth it to look at the config.
I see you have two wireguard remote connections, that seems fine, wireguard address is fine.
The access list you created is problematic, especially using it as a WAN input source for ether2??
Not sure what you are trying to do here…more mysteries that need to be unravelled prior to any config review.
Thank you for your review.
Indeed, PF on ether1 was an old configuration that is not in use and I just deleted. When needed I can post the most recent changes.
Access Lists (not sure if that is a correct configuration) does intend to restrict the login access to the router, and allow only certain IPs.
Yes the latest config,
In terms of restricting access TO the router input chain..
The only connection, TO the ROUTEr, should be VPN connections and thus no restrictions required.
Connection to the LAN, aka to servers, can be limited by sourc address list on the dstnat rules.
Sure, that totally makes sense. It is more secure.
Here is the latest config
# 2024-05-27 13:33:36 by RouterOS 7.15rc3
add admin-mac=74:4D:28:84:6C:D2 auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
 /routing table
add fib name=useWAN2
add fib name=useWAN1
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10 \
    path-cost=10
add interface=ether2 list=WAN
 /32 interface=wireguard1 name=peer1 public-key=\
    "Q9DT32+x1OrsRAJkdUbxsHG5Bj8BGmWIqeOBZ9ilOiw="
add address=192.168.88.1
 /24 comment=defconf interface=bridge network=\
    192.168.88.0
 /ip cloud
set ddns-enabled=yes ddns-update-interval=1m
 /ip dhcp-client
add add-default-route=no comment=defconf interface=ether1
add default-route-distance=5 interface=ether2 script=":if (\$bound=1) do={\r\
    \n:local gw \$\"gateway-address\"\r\
    \n
 /ip route set [ find comment=\"Secondary WAN\" gateway!=\$gw ] gateway=\
    \$gw\r\
    \n
 /ip route set [ find comment=\"Wan2 Routing table\" gateway!=\$gw ] gate\
    way=\$gw\r\
    \n}" use-peer-dns=no use-peer-ntp=no
add address=cloud.mikrotik.com list=MyCloud
add address=cloud2.mikrotik.com list=MyCloud
 /16 list=Access
add address=190.120.0.0
 /16 list=Access
 /8 list=Access
 /8 list=Access
    protocol=udp
    10.20.1.0
 /24
    invalid
    connection-state=established,related disabled=yes hw-offload=yes
 /ip firewall mangle
add action=mark-routing chain=output dst-address-list=MyCloud dst-port=15252 \
    new-routing-mark=useWAN2 passthrough=no protocol=udp
add action=mark-routing chain=prerouting dst-port=13231 new-routing-mark=\
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
    ether2 new-connection-mark=incomingWAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=incomingWAN2 \
add action=mark-connection chain=input comment=Wan1 connection-mark=no-mark \
    in-interface=ether1 new-connection-mark=wan1_conn passthrough=yes
add action=mark-routing chain=output connection-mark=wan1_conn \
    new-routing-mark=useWAN1 passthrough=no
add action=mark-connection chain=forward connection-mark=no-mark disabled=yes \
    dst-address-type=!local new-connection-mark=wan1_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:2
 /0 src-address=\
    192.168.88.0
 /24
    dst-address-type=!local new-connection-mark=wan2_conn passthrough=yes \
 /1 src-address=\
    192.168.88.0
 /24
add action=mark-routing chain=prerouting connection-mark=wan1_conn disabled=\
    yes new-routing-mark=useWAN1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=wan2_conn disabled=\
    yes new-routing-mark=useWAN2 passthrough=no
add action=dst-nat chain=dstnat comment="serv " dst-port=24000 \
    in-interface-list=WAN protocol=tcp src-address-list=Access to-addresses=\
    192.168.88.10 to-ports=22
add check-gateway=ping comment=Netw disabled=no distance=1 dst-address=\
    0.0.0.0
 /0 gateway=1.1.1.1 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=32
add comment="Secondary WAN" disabled=no distance=3 dst-address=9.9.9.9
 /32 \
    gateway=190.199.224.1 pref-src="" routing-table=main scope=10 \
    suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=1.1.1.1
 /32 gateway=172.16.0.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=31
add disabled=yes distance=3 dst-address=8.8.8.8
    target-scope=31
add check-gateway=ping comment="Wan2 Routing table" disabled=no distance=1 \
    dst-address=0.0.0.0
 /0 gateway=190.199.224.1 pref-src="" routing-table=\
    useWAN2 scope=30 suppress-hw-offload=no target-scope=10
(1) Okay so if your port forwarding was old news and not required, then why do you still have dstnat port forwarding rule…
(2) I don’t recall seeing a name entry in allowed IPs?
add allowed-address=10.20.1.2/32 interface=wireguard1 name=peer1??? public-key=
“Q9DT32+x1OrsRAJkdUbxsHG5Bj8BGmWIqeOBZ9ilOiw=”
(3) Add to list.
(4) Filter rules modified.
add address=192.168.88.XY list=Authorized comment=“admin local PC”
add address=10.20.1.2 list=Authorized comment=“admin remote laptop”
{ default rules to keep }
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input dst-address=127.0.0.1
{ admin rules }
add action=accept chain=input comment=“WG handshake” dst-port=13231 protocol=udp
add action=accept chain=input comment=“admin access” in-interface-list=LAN src-address-list=Authorized
add action=accept chain=input comment=“users services” in-interface-list=LAN dst-port=53 protocol=udp
add action=accept chain=input comment=“users services” in-interface-list=LAN dst-port=53 protocol=tcp
add action=drop chain=input comment=“drop all else” { ensure you put this rule in LAST }
add action=fasttrack-connection chain=forward connection-state=established,related disabled=no hw-offload=yes connection-mark=no-mark
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“Wg to LAN” in-interface=wireguard1 dst-address=192.168.88.0/24
**add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat disabled=yes { enable or remove as required }**
add action=drop chain=forward comment=“drop all else”
(5) MANGLING, we know that mangling doesnt quite solve the wireguard requirements due to bug in the software, however we will approach the problem as though it works and make some necessary adjustments.
Typically mangling has three main thrusts.
a. traffic to the router ( services on the router, such as wireguard )
b. traffic to the LAN ( servers etc…)
c. Traffic from the LAN ( PCC or forcing specific users out a specific WAN )
In this scenario I only see A, which means we need to attempt to ensure any traffic coming on WAN2 departs on WAN2
/ip firewall mangle
add chain=input action=mark-connection in-interface=WAN2 connection-mark=no-mark
new-connection-mark=fromWAN2 passthrough=yes
add chain=prerouting action=mark-route connection-mark=fromWAN2
Done!
6. Routing is the next hurdle. In this case we need the two main table routes and then one special table route for WAN2 and wireguard handshake and tunnel traffic.
Appears to be recursive based, fixed:
add check-gateway=ping distance=1 dst-address=0.0.0.0 /0 gateway=1.1.1.1 routing-table=main scope=30 target-scope=32
add check-gateway=ping distance=3 dst-address=0.0.0.0/0 gateway=9.9.9.9 routing-table=main scope=30 target-scope=32
add distance=1 dst-address=1.1.1.1/32 gateway=172.16.0.1 routing-table=main scope=30 target-scope=31
add distance=3 dst-address=9.9.9.9/32 gateway=190.199.224.1 routing-table=main scope=30 target-scope=31 comment=“WAN2 Routing”
Now for the special table.
add dst-address=0.0.0.0/0 gateway=190.199.224.1 routing-table=useWAN2 comment=“WAN2 Routing”
7. Now, we will revisit IP Routes, additions in purple.
The issue in this para is your IP DHCP CLIENT script and settings for the dynamic WAN2.
To ensure the IP routes are changed when WAN2 is updated there is a couple of more steps to consider.
Its mostly there actually… but simplified!!
add default-route-distance=5 interface=ether2 script=“:if ($bound=1) do={\r
\n:local gw $"gateway-address"\r
\n
/ip route set [ find comment="Secondary WAN" gateway!=$gw ] gateway=
$gw\r
\n
/ip route set [ find comment="Wan2 Routing table" gateway!=$gw ] gate
way=$gw\r
\n}” use-peer-dns=no use-peer-ntp=no
TO:
add default-route-distance=255 interface=ether2 script=“:if ($bound=1) do={\r
\n/ip route set [ find comment="WAN2 Routing" gateway!=$gw ] gateway=$gw\r
\n}\r
\n” use-peer-dns=no use-peer-ntp=no
Note: The entry of a default route distance means default route=yes has been selected.
  1. Now the secret sauce for WAN2 wireguard to actually work, a NAT RULE.
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=dstnat chain=dst-nat in-interface=ether2 dst-address-type=local dst-port=13231 protocol=udp to-address=172.16.0.1
Basically, we trick the router into ensuring any wireguard traffic that incorrectly bleeds from WAN1 is un-destinatted to WAN2! :slight_smile:
