VPN PPTP how to access local machine?
I have user on the internet that access my mikrotik router via PPTP vpn.
But he did not see PC on the local network.
I add rules to firewall, add proxy-arp to all interfaces - nothing help.
Local PC is on wifi connected to LAN over bridge.
Where can be problem and how i can fix it?
Are you using routed mode or bridged? Only in bridge mode you can access windows shares.
My router is in routed mode, i check bridge mode - works nothing, no internet and etc.
I need simple configuration each any low-cost router have - ethernet internet connection and VPN local network supporting RDP - all manuals for mikrotik do not work, maybe something has changed in mikrotik OS, i do not know.
What can i do to make it work? (mikrotik)
