I am problem.
I want connect VPN between MIKROTIK 1100x2 (Site A) and more than 20 site using Mikroitk RB750 (Site B)
On Site A, LAN is 192.168.0.1/24 and WAN is 72.14.109.11x
On Site B, LAN is 192.168.x.1/24 (with x is number of site an x>0) and cannot using IP WAN because using DCOM 4G.
I want client of Router Site B can access to client and router of Site A
Example : 192.168.1.15 can connect to database of Server at Site A is 192.168.0.2
Thanks you !
You can have a site-2-site vpn with dynamic IP addresses.
In my situation I used this blog.: https://blog.pessoft.com/2016/05/29/mikrotik-ipsec-tunnel-with-ddns-and-nat/
In your case you have to run the script (for updating DDNS) only at the 20 sites.
In site B I using dcom 4g, I get is Local IP ( same 192.168.0.1/24) from ISP to access Internet so it cannot NAT.
When your 4G router really uses 192.168.0.1/24 you have an interesting problem at hand.
Your easiest solution would be either to change the main site LAN address (e.g. to 10.0.0.1/24 or 192.168.100.1/24)
or to change the local network address of the 4G routers (when that is possible).
When both are impossible, well you will have to craft some really ingenious solution that probably is not easy for a beginner… so first consider the above.
I can edit your Lan of Site B. So you can support for me?
