VPN speed reduces drastically over cellular personal hotspot
Model: RB750Gr3
Upgrade Firmware: 7.11.2
At home I use my Iphone (cellular VPN connection) to connect to the office network. The internet speed (in the Iphone) of this connection is very good (about 70Mbps).
Then I stop using VPN in the Iphone and try to use the same VPN (L2TP) connection in my Laptop (internet I share from this Iphone using Personal Hotspot).
Before connecting to VPN, the internet speed in the laptop is very good (about 70 Mbps), but when I connect to VPN the internet speed reduces drastically (sometimes less than 1Mbps).
Can you help to solve this speed issue?
Thanks!
Probably nothing to do with your Mikrotik router ?
What type of VPN ? I assume you launch it on your laptop ?
Can you make a small drawing indicating all mentioned pieces and how they interact with each other ?
Because since you mention hotspot on your phone, what has Hex still to do then ??
  1. From anywhere in the city my iPhone acts as an access point (basically becomes the Wi-Fi router). The internet speed (in the iPhone) is good.
  2. Then my PC (laptop) connects to this Wi-Fi iPhone “hotspot/access point” and browses the internet. The internet speed (in the PC) is good.
  3. In my PC I have a VPN ( L2TP) connection to connect to Mikrotik router to connect to my office network. I connect to this VPN connection. The internet download speed (in the PC) reduces drastically.
  4. In my PC I have a VPN ( PPTP) connection to connect to Mikrotik router to connect to my office network. I can’t connect to this VPN connection at all using this topology. I got an error.
  5. In the same iPhone I have a VPN (L2TP) connection to the same router. I connect to this connection and there is no problem with the speed.
    I tried to use different iPhone – the result was the same.
Internet speed in my office is very good.
Other scenario:
  1. At home I use the regular wifi in my PC (laptop). The internet speed (in the PC) is quite good.
  2. In my PC I have a VPN ( L2TP) connection to connect to Mikrotik router to connect to my office network. I connect to this VPN connection. The internet download speed (in the PC) reduces drastically.
  3. In my PC I have a VPN ( PPTP) connection to connect to Mikrotik router to connect to my office network I connect to this VPN connection. The internet speed (in the PC) remains practically the same.
    There is a problem with (L2TP) connection download speed and VPN (PPTP) connection when I am using my iPhone.
Can you help to solve them?
