I have been trying without success to use IPSec to connect from my Linux machine to my Mikrotik router. I have IPSec + XAuth working with my Android phone and tablet, but this configuration does not appear to work with the OpenSwan or StrongSwan network settings parameters.
Has anyone been able to successfully connect a Linux client to the Mikrotik router using IPSec, and if so, what configuration is being used on both sides?
I had the same issue a while ago. I managed to get it working installing on my (Linux Mint Tara) strongswan with network-manager-l2tp. I’m using L2TP with IPSEC, just make sure to insert on your Linux what encryption algorithms you are using.
i’m using the MikroTik with IKEv2 and EAP + RADIUS (FreeRADIUS).
Radius is used for the authentication and assigning fixed (virtual) IP-Addreses to the RoadWarriors. In this configuration, strongSwan clients and Windows clients can establish a connection to Router. Also strongSwan running on Android is working.
