VRF & Client Mirkotik with same IP Address & didnt have Gateway IP (PLC)
Hi All,
I have a case with a solution network. I have a lot of PLC witch same IP Address want to connect to existing Network. is it possible to all of PLC connect to 1 Router Mikrotik using VRF or other solution?
Existing Network :192.168.100.0/22
Server : 192.168.100.1/22 gw:192.168.103.254
PLC-1 : 192.168.250.1/24
PLC-2 : 192.168.250.1/24
PLC-3: 192.168.250.1/24
PLC-4: 192.168.250.1/24
New Mikrotik connect to the Switch (192.168.103.254).
my case is, Server want to remote to PLC using NAT IP (192.168.100.x/22) of the each PLC. I have a trouble with this, cause all of PLC didnt have Gateway IP setting. Hopefully all of you can give me the advise/solution. Thanks
Should be this case:
