So, a VRRP instance with Sw01 priority’s set to 150, preemptive mode=yes, Sw02 priority=50. This means that once Sw01 comes online, it should take ownership of the VRRP instance, right? The thing is… it’s not happening:
And I have no clue why.
How to replicate:
Set everything up
Make sure Sw01 is the owner of the VRRP instance
Unplug power from Sw01
Sw02 becomes the VRRP owner
Plug back Sw01
Wait and see - 15 mins in the waiting, Sw02 is still the owner
I just saw that if I change the priority of either VRRP instances (Sw01 or Sw02), VRRP is getting the correct ownership.
Please check the RouterOS Log and see if there are any VRRP-replated messages on both routers. When sync-connection-tracking=yes, the devices sync their connections before changing the master. Maybe there is something wrong with connection sync. Also, try disabling sync-connection-tracking to see if it fixes the preemption.
Just to be sure, there are no other VRRP routers in the 10.41.199.0/24 subnet except these two, right?
[admin@Sw01] > /log/print
08:10:37 system,error,critical router was rebooted without proper shutdown
08:10:37 interface,info lo link up
08:10:37 interface,info v199 link up
08:10:37 vrrp,info vrrp now BACKUP
08:10:37 vrrp,info vrrp starting CTSYNC BACKUP
08:10:37 bridge,info "b1" mac address changed to 0C:8C:28:CA:00:00
08:10:37 vrrp,info vrrp stop CTSYNC
08:10:39 system,info,account user admin logged in via local
08:10:39 vrrp,info vrrp stop CTSYNC
08:10:39 vrrp,info vrrp starting CTSYNC BACKUP
While I’ve got both firewall and vrrp logging enabled
VRRP Preemption should work together with sync connection tracking, but it doesn’t work on your side for some reason. Please create a support ticket, and we will try to reproduce your issue.
