Hi guys,
Been testing VXLAN over WireGuard between two remote sites through a WG hub router and found some really interesting behavior.
What works:
VXLAN tunnel comes up
VLAN tags pass correctly
broadcasts/ARP pass
DHCP Discover packets visible remotely
MACs appear in VXLAN FDB
What does NOT work:
DHCP replies never return
static IP clients cannot ping remote gateway
unicast forwarding seems broken
The strange part is both routers dynamically learn MACs against the WG hub IP instead of the actual remote VTEP IP.
So now I’m wondering if this is:
a flood-and-learn VXLAN limitation
MikroTik VXLAN behavior
routed overlay issue
or lack of EVPN/static FDB logic
Funny thing is EoIP over the exact same topology works perfectly.
Curious if anyone else has tested VXLAN over routed WireGuard hub/spoke designs and seen similar behavior.
