Hi All.
We want to create a walled garden rule that will allow traffic if a certain string is contained with in the URL/path..
i.e www.mydomain.com/xyx_test/cy
If test is in the URL/Path the rule needs to apply. We have tried multiple iterations
“\btest\b”
//.test./
“:/test/$”
etc
in both path and dest host
can someone please advise what the correct syntax would be and the correct format of the walled garden rule
Can not work on http**S**
You can not read URL inside any version of HTTPS.
One exception is only the domain name on SNI, but on firewall, until the version is TLS 1.2 or lower
Thanks for the reply
Appreciate the input.
Back to the drawing board
Other protocols can also be included in Walled Garden, but that is configured elsewhere (in /ip hotspot walled-garden ip; see the next section of this manual for details)
Property Description
action (allow | deny; default: allow) - action to undertake if a packet matches the rule:
allow - allow the access to the page without prior authorization
deny - the authorization is required to access this page
dst-address (IP address) - IP address of the destination web server
dst-host (wildcard; default: “”) - domain name of the destination web server (this is a wildcard)
dst-port (integer; default: “”) - the TCP port a client has send the request to
method (text) - HTTP method of the request
path (text; default: “”) - the path of the request (this is a wildcard)
server (name) - name of the HotSpot server this rule applied to
src-address (IP address) - IP address of the user sending the request
Notes
Wildcard properties (dst-host and dst-path) match a complete string (i.e., they will not match “example.com” if they are set to “example”). Available wildcards are ‘*’ (match any number of any characters) and ‘?’ (match any one character). Regular expressions are also accepted here, but if the property should be treated as a regular expression, it should start with a colon (‘:’).
