Hi all
I’m unable to find the beam width / degree of cover for the wAP ac LTE kit (2024). All previous wapac’s seem to be omni / 360 degree but before purchase I’d like to confirm (brochure is mum on this and not sure what else to search for in Mikrotik terms)
At least the wAP Ax is not 360°, but declared on the brochure as 180° (which makes sense for something that is intended to be placed on a wall or ceiling) but that from the FCC documentation seems like a ball with flat bottom, with an angle more in the 90° to 120° range: wAP coverage -- picture included - #8 by jaclaz
Yep, if we assume that - as stated by Normis - the “w” stands for wall, it would be logical that a “w” device is not 360° but 180° or less, so the wAP Ax declared angle is fine.
The question is:
"Did Mikrotik manufacture for years other “w” devices as omnidirectional and only when designing the wAP Ax became aware that on one side of the device intended mounting there is a wall and makes little sense to send signal in that direction?
Or are all “w” devices hundredeightydegreesish?
