wAP ac mounting solutions
I recently bought a used wAP ac, however it didn’t come with any mounting hardware whatsoever.
Does MikroTik still sell any mounting hardware for the wAP ac? I’ve been looking at the QMP, would that fit?
It looks like wAP ac has same physical dimensions as newer wAP ax and used to come with same included parts (like mounts and desktop stand). So you might be lucky to get one of those kits from some wAP ax owner who doesn't need parts.
QMP would likely not fit ... and my guess is based on looks of included mounting pieces ... I guess (I have a wAP ax, which stands in a desktop stand, so no actual idea how to mount it differently) that pole mounting is done using "wAP mount" plate and "metal ring" ... and that metal plate seems to have different mounting holes layout than QMP. Look at the parts on WAP ac product page.
If you have (or some friends have) a 3D printer there are files for it:
https://www.printables.com/model/1116635-mikrotik-wap-ac-wall-mounting-bracket
https://www.thingiverse.com/thing:4128057
https://www.printables.com/model/1277640-mikrotik-wap-wall-mount/related
https://www.wanhunglo.com/2019/mikrotik-wap-ac-door-jamb-bracket-p16
