New WAP ax owner and Mikrotik newby here, switching over from a legacy Cisco solution. Been setting up the wAP from a blank configuration as an AP. Device is direct to 1GB router (speed verified). Speeds limited to about 60Mbps consistently regardless of testing device. Updated RouterOS and Routerboard. No congestion at all on selected frequencies. Device is sitting on wall in line-of-sight about 10m away. Below is my config. Any suggestions on how to tweak is appreciated.
# 2026-05-21 10:17:05 by RouterOS 7.22.3
# software id = *****
# model = wAPG-5HaxD2HaxD
# serial number = *****
add name="Main Bridge"
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .frequency=2452 .width=\
20/40mhz configuration.country="United States" .mode=ap .ssid=\
Tuweap_test_2GHz disabled=no name=Tuweap_test_2.4GHz \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=5ghz-ax .frequency=5240 .width=\
20/40/80mhz configuration.country="United States" .installation=indoor \
.mode=ap .ssid=Tuweap_test_5GHz disabled=no name=Tuweap_test_5GHz \
add bridge="Main Bridge" interface=ether1
add bridge="Main Bridge" interface=Tuweap_test_2.4GHz
add bridge="Main Bridge" interface=Tuweap_test_5GHz
add address=192.168.0.3/24 interface="Main Bridge" network=192.168.0.0
/ip dhcp-client
add interface="Main Bridge" name="WAP ax1"
/system clock
set time-zone-name=America/Denver
