wAP LR8 kit reset procedure
Dear all,
my wAP LR8 kit stopped working - only the yellow Ethernet led is slowly flashing, no IP traffic on the interface. I tried to reset it with the reset button, but no luck: As soon as I power it up with the reset button pressed, a green led inside flashes quickly. It then lights continously for second, then it goes off. Afterwards yellow ETH led slowly flashes. No matter when I release the rest button, the result is always the same: It does not pop up under neighbors on an adjacent router.
Does the wAP LR8 kit have a different reset procedure? Otherwise it probably compelety died for some reason…
Joachim.
PS: It does not show up with netinstall, either.
Can you access it through mac-telnet winbox? If so, try:
/system reset-configuration skip-backup=yes
Unfortunately I cannot access the router this way. The copper interface establishes a link, but there is no traffice going over it.
Try Netinstall, don’t forget to add LoRa package as well:
https://help.mikrotik.com/docs/display/ROS/Netinstall
Unfortunatey it won’t come up in netinstall. I guess it’s a hardware failure after only 1 1/2 years.
