I have LR8G kit + external omni antenna and I am trying to link TR-LR92 sensors. Sensors seem OK, they respond to the magnet commands, anyway, I can't see any traffic in the router traffic monitor. I can see pretty much anything, except the sensors. I've tried commands 2, 3-1, restart, even factory reset, nothing helps. Also I am not sure if the antenna gain is ok if there is not some hw problem... Any help appreciated.
Yes, I've got Chirpstack. In fact I've received a join message twice and the Chirpstack sent a response (not sure if received by TG sensors). These messaged were also shown in the LR8G console. Anyway, I have no idea what causes these request joins, there are no periodical messages, no measurement messages and I cannot force TG's cast even using the magnetic commands, althougn LED's response as expected.
Until device joins network uplink command 3-1 will have no effect. This command schedules frame as pending. All periodic telemetry will be sent after device has joined.
Your screenshots show only reception of messages. I don't see any join accept sent by this GW. Since you're using Chirpstack (locally I presume) TX must be sent by your LR8G kit. Check that GW and chirpstack report both join request and join accept messages. You can inspect messages to Dev EUI and Join EUI if needed.
The corresponding messages were shown in the console.
How can I force the TG-LR92 to send another join request? I tried 6-1 or 2, even 6-9-9 but since the above messages, no other message was sent. Thank you.
Just to clarify this. After device is activated it will continuously send join requests. By default it sends one request using sub-GHz band and one in 2.4GHz band. You can disable either to reduce interval for used band if its important for use case. Magnet commands: "4-3-9" and "4-2-1", "4-2-2" or downlink commands.
Both frequency and data rate are randomized. Delays between attempts are determined by used data rate so it may fluctuate.
Device will not only follow regional limits, but also LoRaWAN specification.
