Hi, I have a WB RBwAP2nD which I have configured to work in point-to-point mode. this device is set in bridge mode. with my configuration, I connect to the main device and the router assigns the IP to my PC, but I cannot access the Internet. I made a basic configuration. where am i wrong?
here my setting
If NAT is needed, then the outgoing interface , with NAT, cannot be connected to the bridge, and will have its own (through DHCP client?) IP address in another subnet than the bridge.
If it is just bridging wifi to ethernet, then there can be no NAT. The IP address will come from the upstream internet router
Sincerally, i just followed a tutorial because i’m noob with mikotik OS and in every tutorial i’have read there is a NAT is applied to the bridge…
Now, I have assigned the ip to the ethernet and setted the DNS and everything works.
Here the code.
