Hello, All
When following such a structure, I would like to the routing process to Azure side,
probably because you are using ECMP, routing to the Azure side fails to even.
Will you what should be in such a case of setting?
add check-gateway=ping distance=5 dst-address=10.0.0.0/11 gateway=21ip routing-mark=\
azure
add check-gateway=ping distance=1 gateway=gmobb-giga,21ip
add chain=srcnat dst-address=10.0.0.0/8 out-interface=21ip src-address=192.168.122.0/24
/ip firewall mangle
add action=mark-routing chain=output dst-address=10.0.0.0/8 new-routing-mark=azure \
passthrough=no
Best regards.
