what is the difference between bridging LANs over point to point link using WDS and EOIP? What are pros and cons of these two protocols?
I have 2,5 km point to point link, bridging over EOIP, wireless Atheros 2511, turbo mode, 54 Mbps tx and rx - but the troughput is 12Mbps half duplex. I use RB220, cpu load comes up to 98% when traffic reach 12Mbps in total. Would it be better to use WDS for this?
we are using WDS for a point to point link that is 1.2 miles. Our throughput is 13megs not using turbo mode and setting the basic rates between 6-18megs. When i ran the bandwidth-test the link was set to 18Mbps and the cpu was at about 98%.
You should leave the basic-rate at the lowest rate – the default. Playing with this may only help on links that have a perfect connection and it won’t help enough to warrant it.
