hi ,
can anyone tell me IN WDS what is diff. between static and dynamic.
it will affect on performance or not?
hi ,
the difference is obvious, one creates itself, the other you need to make by hand (add all mac addresses). there are pros and cons to each.
thank u normis.
What are the pros and cons of each, AND can someone explain the WDS cost for us?
Adam
it’s obvious really …
static:
dynamic:
http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless_content.php#4.13.10
hi normis
i m stucked at one point i hope some one will help me.
i m connecting 2 AP using WDS static.its working fine.i have one question
is it possible to connect client (station mode) to AP or not?if it possible then how can i connect?
i m trying to connect like this: but i can’t
AP----->wireless interface------>access list----->MAC add of client(station mode)
plz plz some one help me .
thanx in advance.
Yup..
here i used ap2ap than set station on 'access-list' is working
simple mean i have divices on 'access-list' when it as station and 'connect-list' as static-wds will connect to my roam. .... nice ![]()
