In connection with previous post…
V3.23 SSL Proxy Issue:
Have not tested if this still exists in v3.24
FYI: Exact same bug exists in v3.24
Please, contact support (support@mikrotik.com) about HTTPS issues.
so how can i work around this
network--------x86----eth1—adslmodem1
----eth2----adslmodem
----eth3----mailserver
----eth4----x86proxy----------adslmodem
so i have a nat to redirect 80 trafic to proxy
but i want 445 trafic to go throught the same modem as proxy traffic
Old thread. Damn
i can see that so there must be a salution correct
or has it been fixed
can i redirect https through the proxy yes or no???
I never have to. You should never have to as well. It will only pass through or it will break. It does not cache encrypted objects so there would be no point.
RouterOS Proxy doesn’t support transparent proxying of https
thanks i found a salution to my problem
hi xezen
can u tell me what is your soulotion ?
