Web Proxy Maximum Size Problem..
Hi guys
I have v.2.9.27 installed on a 20GB ide drive with a 400Mhz PIII Processor.
I have set the Maximum Cache Size as 18000000KiB thinking that this means approximately 18GB of cache. The cache has started to grow from 0KiB until 4260552KiB and then stopped. I see on the Winbox that “Reserved for Cache” is 4733952. Does anyone know the reason why my cache has stopped to grow, and how can i really make the “Reserved for Cache” 18GB ??
Is this a problem with the router resources ??
Thanks in advance for any help
How about RAM?
So your system should have at least 18*15=270 +55 =325MB RAM
Yep man. Thay may be the problem..my system now has only 128Mb of size… and as of the calculations..the size it has now is right :slight_smile:
I’ll upgrade it tonight..
You are right man. I increased the RAM size and MT automaticly changed the “reservde for cache” in about 16GB.
Mikrotik Rocks. :slight_smile:
