I’m setting up an RB500 as a non-caching proxy using one ethernet port. So far, I have http proxying working but I’ve run into some problems:
1: I can’t find any documentation for webproxy-test.
2: How do I install the non-test version of webproxy. It doesn’t appear in the package list.
3: HTTP is working, but HTTPS does not. Can I do this?, how?
4: Some pages using HTTP and aspx didn’t display in the browser. Do I need to set anything up to specifically handle this?
[admin@MikroTik] ip proxy> pr
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0:0
cache-drive: system
cache-administrator: "webmaster"
max-disk-cache-size: none
max-ram-cache-size: none
cache-only-on-disk: no
maximal-client-connections: 1000
maximal-server-connections: 1000
max-object-size: 4000KiB
max-fresh-time: 3d
Regards
Andrew
