Web Proxy queue
I have a problem with traffic shapping from web proxy.
I mark mac address,ports,ip and nothing works.
Can`t find a way to limit traffic if web proxy is enabled.
Any Ideas?
Thanks.
Maybe you can try this example
P > FIREWALL > MANGLE
0 ;;; up traffic
chain=prerouting in-interface=LAN src-address=192.168.0.4 action=mark-packet new-packet-mark=test-packet-up passthrough=no
1 chain=forward src-address=192.168.0.4 action=mark-connection new-connection-mark=test-conn passthrough=yes
2 ;;; down traffic from internet
chain=forward in-interface=PUBLIC connection-mark=test-conn action=mark-packet new-packet-mark=test-packet-down passthrough=no
3 ;;; down traffic from router
chain=output out-interface=LAN dst-address=192.168.0.4 action=mark-packet new-packet-mark=test-packet-down passthrough=no
QUEUE > TREE
0 name=“test-down” parent=LAN packet-mark=test-packet-down limit-at=0 queue=default priority=8 max-limit=64000 burst-limit=0 burst-threshold=0 burst-time=0s
1 name=“test-up” parent=global-in packet-mark=test-packet-up limit-at=0 queue=default priority=8 max-limit=64000 burst-limit=0 burst-threshold=0 burst-time=0s
hello
i have same problem,my queue would fine but when enables squid for me web catch the queue tree wiil shape well for me pl what i should now .
valens so nice example , i want to apply your example but first i need to show you my rules wich i’m using now , i just want to make an equal bandwidth sharing between my clients ( PCQ ) and i’m doing this :
1- firewall mangle :
chain=prerouting src-address=192.168.1.0/24 action=mark-connection new-connection-mark=users-con passthrough=no
chain=forward connection-mark=users-con action=mark-packet new-packet-mark=users passthrough=yes
2-Queues
a- type
name=“pcq-download” kind=pcq pcq-rate=0 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000
name=“pcq-upload” kind=pcq pcq-rate=0 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=2000
b- tree
name=“queue1” parent=localnet packet-mark=users limit-at=0 queue=pcq-download priority=8 max-limit=0 burst-limit=0
name=“queue2” parent=internet packet-mark=users limit-at=0 queue=pcq-upload priority=8 max-limit=0 burst-limit=0
please look at this setting carefully and let me know if i made any mistake , and how to add a queue for my web-proxy to the download queue .. thanx in advanced
i need someone to check my setting please , is it ok ? or i have to change it to valnet example ?
please any EXPERT advice ???
Guys, I´m not an expert, very far of that.
But, I´m using this for my clients
Hope to be useful for you.
Regards,
Fernando
Configuro Mangle PARA PRIORIDADES
Configuro Mangle VoIp
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=5060 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="VoIP" disabled=no
/ ip firewall mangle add chain=prerouting protocol=udp dst-port=5060 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=16384 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting protocol=udp dst-port=16384 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=19000-20000 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting protocol=udp dst-port=19000-20000 action=mark-connection new-connection-mark=VOIP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=VOIP_CON action=mark-packet new-packet-mark=ALTA passthrough=no comment="" disabled=no
Configuro Mangle DNS
/ ip firewall mangle add chain=prerouting protocol=udp dst-port=53 action=mark-connection new-connection-mark=DNS_CON passthrough=yes comment="DNS" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=DNS_CON action=mark-packet new-packet-mark=ALTA passthrough=no comment="" disabled=no
Configuro Mangle Trafico Web
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=80 action=mark-connection new-connection-mark=HTTP_CON passthrough=yes comment="HTTP" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=443 action=mark-connection new-connection-mark=HTTP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=8080 action=mark-connection new-connection-mark=HTTP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=HTTP_CON action=mark-packet new-packet-mark=MEDIA_ALTA passthrough=no comment="" disabled=no
Configuro Mangle Trafico Mail
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=110 action=mark-connection new-connection-mark=MAIL_CON passthrough=yes comment="HTTP" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=25 action=mark-connection new-connection-mark=MAIL_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=MAIL_CON action=mark-packet new-packet-mark=MEDIA_ALTA passthrough=no comment="" disabled=no
Configuro Mangle Trafico FTP
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=20 action=mark-connection new-connection-mark=FTP_CON passthrough=yes comment="HTTP" disabled=no
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=21 action=mark-connection new-connection-mark=FTP_CON passthrough=yes comment="" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=FTP_CON action=mark-packet new-packet-mark=MEDIA_BAJA passthrough=no comment="" disabled=no
Configuro Mangle Messenger
/ ip firewall mangle add chain=prerouting protocol=tcp dst-port=1863 action=mark-connection new-connection-mark=MSN_CON passthrough=yes comment="MSN" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=MSN_CON action=mark-packet new-packet-mark=MEDIA_BAJA passthrough=no comment="" disabled=no
Configuro Mangle Para Programas Peer to Peer
/ ip firewall mangle add chain=prerouting p2p=all-p2p action=mark-connection new-connection-mark=P2P_CON passthrough=yes comment="P2P" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=P2P_CON action=mark-packet new-packet-mark=P2P passthrough=no comment="" disabled=no
Configuro Mangle Resto de los Servicios
/ ip firewall mangle add chain=prerouting action=mark-connection new-connection-mark=OTROS_CON passthrough=yes comment="Resto del trafico" disabled=no
/ ip firewall mangle add chain=prerouting connection-mark=OTROS_CON action=mark-packet new-packet-mark=BAJA passthrough=yes comment="" disabled=no
######## Configuro el Arbol de Colas Queue tree #################
/ queue tree add name="8-P2P" parent=global-out packet-mark=P2P limit-at=64000 queue=default priority=8 max-limit=128000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
/ queue tree add name="1-Alta" parent=global-out packet-mark=ALTA limit-at=0 queue=default priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
/ queue tree add name="3-Media alta" parent=global-out packet-mark=MEDIA_ALTA limit-at=0 queue=default priority=3 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
/ queue tree add name="5-Media baja" parent=global-out packet-mark=MEDIA_BAJA limit-at=0 queue=default priority=5 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
/ queue tree add name="7-Baja" parent=global-out packet-mark=BAJA limit-at=0 queue=default priority=7 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
Search on my post.
The conclusion is that on mk you cannot mangle proxy request.
ciao
maxfava , thats mean if a client request somthing about 1Mb , and his request exist inside the cache , he will recieve the 1Mb out of the limit in the mangle and queue ??
Just one idea:
add chain=output protocol=tcp src-port=8000 (proxy port) dst-address-list=“your list here” action=mark-packet new-packet-mark=proxy-out passthrough=yes comment=“” disabled=no
/ queue tree
add name=“proxy-out” parent=global-out packet-mark=proxy-out limit-at=1 queue=default priority=5 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=yes
PS: tested, works
i dont understand why the (( disabled=yes )) ?
anyway , there is more than one setup each user wrote his setup solving the same problem , and no one from mikrotik say a word !!! i dont know whos this form belongs to ??
i bought MT for a specific need , untill now i saw more than one setup all of them differ from the setup in the manual , i’m totaly lost …
Yes that’s right we can not mangle proxy request if web proxy was enabled
