hello thx for your reply
here is my config
# ADDRESS NETWORK BROADCAST INTERFACE
0 net 1
xxx.xxx.13.54/30 xxx.xxx.13.52 xxx.xxx.13.55 ether1
1 ;;; retea
192.168.1.1/24 192.168.1.0 192.168.1.255 bridge1
here is my route table
[admin@MikroTik] > ip route print
# DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable xxx.xxx.13.53 1 ether1
1 S 0.0.0.0/0 reachable 192.168.2.1 2 ether2
2 ADC xxx.xxx.13.52/30 xxx.xxx.13.54 0 ether1
3 ADC 192.168.1.0/24 192.168.1.1 0 bridge1
the nat
p firewall nat print
0 chain=dstnat action=dst-nat to-addresses=192.168.1.17 to-ports=5900 protocol=tcp
dst-address=xxx.xxx.13.54 dst-port=5900
1 chain=dstnat action=dst-nat to-addresses=192.168.1.16 to-ports=5901 protocol=tcp
dst-address=xxx.xxx.13.54 dst-port=5901
3 chain=dstnat action=redirect to-ports=8080 protocol=tcp src-address=192.168.1.105 dst-port=80
4 chain=dstnat action=dst-nat to-addresses=192.168.1.105 to-ports=22 protocol=tcp
dst-address=xxx.xxx.13.54 dst-port=22
5 chain=srcnat action=masquerade src-address=192.168.1.0/24
6 X ;;;redirectar to squid
chain=dstnat action=dst-nat to-addresses=192.168.1.105 to-ports=3128 protocol=tcp
src-address=192.168.1.0/24 dst-port=80
7 X chain=dstnat action=redirect to-ports=8080 protocol=tcp src-address=192.168.1.105 dst-port=80
ip proxy
ip proxy print
enabled: no
src-address: 0.0.0.0
port: 8080
parent-proxy: 192.168.1.105
parent-proxy-port: 3128
cache-administrator: ""
max-cache-size: none
cache-on-disk: yes
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: yes
always-from-cache: no
cache-hit-dscp: 4
Ok now the redirects are stoped atm, the squid server is 192.168.1.105 if i enable the redirects i see in squid accesslogs
192.168.1.1 but i need to see the all hosts in my log files .
ex: i see now
1277465672.575 5 192.168.1.1 TCP_MISS/401 1110 GET http://www.xxxxxx.com/ - DIRECT/121.15.220.135 text/html
but i want something like this to have in logfile
1277465672.575 5 192.168.1.217 TCP_MISS/401 1110 GET http://www.xxxxxx.com/ - DIRECT/121.15.220.135 text/html
192.168.1.217 its one of the pc are conected
i need any solution to make this work i need to make somehow to see the conected pc-s web traffic
daily monthly top sites when where … etc
like in sarg or any loganalizer.
Thank you for reading
edit: i also tryed with proxylizer and i also get in the log files :
Jun 18 22:52:01 192.168.1.1 web-proxy,account: 78.155.72.142 GET http://t1.gstatic.com/images?q=tbn:SEHFWkyVsilypM:http://www.xxxxxx.com/star-academy/images/nassif-improving.jpg action=allow cache=MISS
