web proxy
hello,
how to secure mikrotik web proxy? too many clients from outside is connected to my proxy.
10x
add firewall rule to block access to your proxy from outside
u can explain me pls ?
10x in advance
Lets say proxy port is 8080 and public interface is “internet”
add chain=input dst-port=8080 protocol=tcp in-interface=internet action=drop
proxy port is 3128
but this rule dont stop outside clients :frowning:
of course it does.
I put this rule first in firewall filter but is never hit-ed, and outside clients is steel connected to my proxy
make sure you move this rule to the top of your firewall, make sure you specified the correct in-interface
all it`s correct …i stoped the proxy server because too manny connection from outside (300 clients from outside)
type “/ip firewall filter export” in the command line, and paste here the output, so we can help you
this is my firewall
/ ip firewall filter
add chain=input in-interface=Public src-address=0.0.0.0 protocol=tcp dst-port=3128 action=drop comment=“”
disabled=no
add chain=input protocol=tcp dst-port=22 connection-limit=0,32 limit=0,5 dst-limit=0,5,dst-address/1m40s
nth=0,0,0 src-address-list=ssh_blacklist action=drop comment=“drop ssh brute forcers” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new src-address-list=ssh_stage3
action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=30m comment=“” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new src-address-list=ssh_stage2
action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m comment=“” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new src-address-list=ssh_stage1
action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m comment=“” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new action=add-src-to-address-list
address-list=ssh_stage1 address-list-timeout=1m comment=“” disabled=no
add chain=forward connection-state=established src-address-list=lan_computer action=accept
comment=“Established connections” disabled=no
add chain=forward connection-state=related src-address-list=lan_computer action=accept comment=“Related
add chain=forward protocol=udp dst-port=53 src-address-list=lan_computer action=accept comment=“”
disabled=no
add chain=forward protocol=tcp dst-port=53 src-address-list=lan_computer action=accept comment=“”
disabled=no
add chain=forward protocol=tcp dst-port=80 src-address-list=lan_computer action=accept comment=“”
disabled=no
add chain=forward protocol=tcp dst-port=443 src-address-list=lan_computer action=accept comment=“”
disabled=no
remove src-address=0.0.0.0
I did it , but …outside clients steel connected
You can us proxy access list to control who has access to the proxy and then deny all others.
/ip proxy access
add action=deny comment="block telnet & spam e-mail relaying" disabled=no dst-port=23-25
add action=allow comment="" disabled=no src-address=192.168.0.0/16
add action=deny comment="deny all others" disabled=no
Replace src-address with your local IP Range.
my mistake
i have pppoe conection
wrong
disabled=no
correct
add chain=input in-interface=pppoe-01 src-address=0.0.0.0 protocol=tcp dst-port=3128 action=drop comment=“”
disabled=no
10x
I have tried this rule, and it is blocking internet users from accessing my web proxy, my firewall counter is constantly adding up, however when i check my web proxy status it is no longer adding any request or hits, when i disable this rule it starts adding requests and hits again. This rule seems to simply disable my web proxy all together.
chain=input action=drop protocol=tcp in-interface=ether1 dst-port=8090
ether1 is my internet port interface.
Any help or insight would be greatly appreciated.
Same discussion below
http://forum.mikrotik.com/t/securing-the-dns-web-proxy/16204/1
