since my update to 6.12 and then 6.13, “quick set” doesn’t display like before (see attach) and it may be a bug because I have the “System” category about 5 time on the page.
Anyone else with the same “problem”?
Thank you.
Thank you.
I not see anything strange on the screenshoht…
ok so is that a new presentation? because before, I had only (if my memory is good) “Local Network”, “Internet” and “system”, with information on each category. Now, I have something about 4 “Local Network” category with zero information
What device is?
it is a VM (I’ve used the PC / X86, RB230 series CD image)
according to this wiki page, if I understand well, Quickset is only available on AP and CPE router. In my case, routeros is used as a NAS (for hotspot purpose) on a virtual machine so I must not have all those options (before updates, it was OK : only 3 options category)
So, is that a bug, or a misconfiguration on my part?
The problem in your system is lack of wireless. We have fixed this problem in v6.14, where QuickSet will also work with disabled wireless package
exactly, I don’t have the wireless package. So I’ll wait for v6.14 and see.
Thank you for aswers
During wait, install and enable wireless package also if you not have wlan.
Thank you but I like to have a minimum of package so I’ll wait for the update because this is not a blocking problem (routeros was already configured and still work perfectly).
Thank you for the .14 update, that solved my display problem.
