webproxy/proxy can i force users to use it?
maybe with the hotspot system?
also does the cacheing system on default does it cache everything or MUST i specify what to cache i have it set to any ?
Yep, ofcourse,
I personaly use ‘manualy settings on client side’, on firewall forward rules, I Reject every tcp request on port 80, so clients internet won’t work without proxy heheh, also you can use ‘transparent proxy’
see ya
@netcomp do you having problem with webproxy…
cause i do.
why is that when the webproxy running normal then about 1 week after suddenley it wont work…!
is it webproxy need to be clear cache
please give me an idea how to force them MUST i do what u sugested netcomp ?with blocking port 80 ?
and how
larmaid - I have a script on my web proxy which reboots every 24h so I never have problems with anything hehe
incomm - I have a network of approx 100 users so I manualy set every user to use proxy’s (Internet explorer - use proxy server x.x.x.x port 8080)
If you have biiig network, I won’t recomend this cause it is time consuming, also when clients format their pc’s you have to teach them how to put proxys, so it would be simpler to use transparent proxy, read the instructions on http://www.mikrotik.com
If you do prefer manual usage, just block tcp port 80 like this:
/ ip firewall rule forward
add src-address=10.0.0.0/24 dst-address=:80 protocol=tcp action=drop
comment=“Drop port 80 for everybody” disabled=no
if you do want to enable any client to use port 80, you just put one action=accept before this which blocks everybody
add src-address=10.0.0.22/32 dst-address=:80 protocol=tcp action=accept
comment=“Accept port 80” disabled=yes
see ya
yes, but i did what it says i can still pass traffic on websites i have blocked on thewebproxy
