What am I missing about Let's Encrypt support?
It’s cool that Mikrotik supports automatic Let’s Encrypt, but isn’t it a major security risk to leave port 80 open to the internet AND need to have the www service running all the time? Why doesn’t the router automatically enable a web server, open firewall ports, renew the cert, then disable the web server and close the firewall? I don’t understand how or why anyone would use this feature as it’s currently implemented. What am I missing?
The code that processes the HTTP requests is the same one regardless whether the requests arrive via plaintext HTTP on port 80 or TLS-encrypted (HTTPS) on port 443. So apart from protection against eavesdropping on the path between the client and the Mikrotik, the security provided by HTTPS boils down to protection of the client credentials against MITM attacks - if the client does not trust the certificate presented by the server, it will not send its username and password.
However, an attacker will not care about the server certificate so they will be able to access the same files/services using HTTP and HTTPS, so if you permit access to the www-ssl service to access the management of the router from the whole internet, it is not any more any more secure against direct attacks than allowing access from the whole internet to the HTTP service.
If you plan to use the Let’s Encrypt certificate maintained by RouterOS for some other service than www-ssl, e.g. for authentication of a VPN server, you can implement the stateful logic you have described above using firewall rules. There should be a recent topic providing the details here. In short, you usa a mangle/output rule to populate a dedicated address-list with the own WAN address of the router for about a minute whenever it sends the request to Let’s encrypt, and you add a rule accepting incoming connections to TCP port 80 from WAN if the destination address matches that address-list:
/ip firewall address-list
add address=acme-v02.api.letsencrypt.org list=lets-encrypt
/ip firewall mangle
add action=add-src-to-address-list address-list=acme-client address-list-timeout=1m chain=postrouting dst-address-list=lets-encrypt src-address-type=local
add action=accept chain=input dst-address-list=acme-client dst-port=80 protocol=tcp
Thanks, yes, I understand it doesn’t matter whether 80 or 443 is available. My point is that the default requires you to expose port 80 with the www service active in order to automate certificate renewal. Thanks for the firewall idea - I’m just confused why MikroTik would design the feature to be insecure like this.
I need to use DNS verification for the certificate anyway, so I’ll just keep using acme.sh on my local Linux box and deploying it to the router from there.
This is exactly the same on all servers that support LetsEncrypt.
It doesn’t have to be. On servers which offer more configuration flexibility one can allow only URLs with path names starting with /.well-known/acme-challenge/ and send 404 for the rest … or 301 redirecting to https … or tarpit requests or whatever.
The part where service on port 80 is running … yes, that has to be true for all servers.
yes, and in RouterOS you can use firewall to only allow connections from Letsencrypt, in either case, some manual protection has to be set up
