What is the latest bootloader for RB2011
I have had to backout version 6.15 because of kernel panic problems which MikroTik dev team are investigating but I would like to ensure that I am at least running the latest bootloader.
How do I download a FWF file from MikroTik? Can’t seem to find the files on the download web page.
Installing the FWF should be simple with the serial port and X-Modem. I am currently running 3.16.
the last is 3.18 and coming out with 6.16
the last directly downloadable are 3.17
http://i.mt.lv/routerboard/files/ar9344_3.17.fwf
You can install it by any RouterOS 6.x version available, simply put on files folder and run system routerboard upgrade
But if I run a routerboard upgrade then will I jump up to 6.16 which I don’t want to do.
Is like you do not have read the post before.
I’m not english, but is not misunderstable.
