What is the meaning of NTH?
Dear all,
I couldn’t understand the meaning of NTH term and how can i use it for load balancing.
Could anybody help me?
I want a document about it that describe clearly.
Thanks a lot for your cooperation.
“nth” should be understood like “second, third, fourth, sixth, seventh” one of those. it means that using this setting, you filter out every “seventh” packet (for example) and decide what to do with it.
see http://wiki.mikrotik.com/wiki/Nth and http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
Thanks a lot for your reply.
I have two internet connections.i want to send 2/3 of my lan tarffic from one of these connection and send 1/3 of these traffic from another connection.
Can I do it with nth?
I want another feature.
I want to if one of these links fail,total traffic send from active connection.
Thanks a lot.
see links above
ok,thank you.
one quiestion.
what is the meaning of nth? or nth is the abbrevation of ?
excuse me.i’m novice and a little stupid
also:
nth (nth)
adj.
  1. Relating to an unspecified ordinal number: ten to the nth power.
