What mikrotik to buy?
Good evening, guys, I’m new to Mikrotik. Then I would like a choice in which equipment to buy.
RB3011UiAS-RM
RB1100AHx2
RB1100AHx4
In the company that we work with we use a very old Rb 1100, I would like to know which one would be more compatible with this, in the best requirement.
What features are you using on your old 1100? Bypass features? Encryption? Etc?
Are you just upgrading because of age or are you encountering any performance issues?
I would think the new 1100’s would would be more inline with your old 1100, but hard to determine your needs.
From these three, the RB1100AHx4 is certainly the best in performance without being very far from the others in terms of cost. But what is most essential is what use you will make of it. Because depending form it, even the 3011 may be overkill.
