What setting is missing?
I trying to connect my modem to the Mikrotik RB450G via VLAN id 10. It seems to have some problem. I am using everything default except a few settings stated below.
Firstly, under Interface I added a VLAN interface under the port of ether1 which connects to the modem. Then under the dhcp client, I add one client using the VLAN interface. It manage to get the public address and gateway. I also connect a wireless ap to ether2 which it is working perfectly giving me ip of range 192.168.88.2 - 192.168.88.254. But the only thing i still cannot get internet access. The routes are default.
What other setting do I miss? Do I need to do VLAN tagging under the switch interface or is bridging required?
Cheers,
Terence
A few points to add I want to use ether1 as a WAN port. And the modem will only gives the public address under the connection of VLAN id 10.
You need to add a masquerade rule for the vlan interface.
add action=masquerade chain=srcnat disabled=no out-interface="your_vlan_interface"
Thanks a lot. It works!
But I got another question. For IPTV, it is also through the same modem and the vlan id is 20. But it seems weird, I could not get any ip from the DHCP client, and how do I do the NAT or any other settings if I want to connect IPTV device via ether4?
One more point to add. Should I put interface for Vlanid20 as ether 1 or Vlanid10?
More than likely ether1. Unless your provider is doing QinQ…
Yea ether1 is correct as i can see RX values but I could get the DHCP client to obtain IP. Is there a need to do anything to switch vlan setting? Because I only used the vlan interface settings.
Do you have your DHCP client on the correct interface?
It will be on the VLAN interface with the id 20 right?
Yea it should be. Does your host have a DHCP server on that vlan?
I am not too sure but what I know is tagging vlan id 10 is for internet and vlan id 20 is for IPTV. I wonder whether is I should do through the switch interface instead.
I did some research, they said something about IGMP spoofing, vendor-id and dhcp relay.
